Wowwee MIP Movement Panel icon Wowwee MIP Movement Panel — UART-based EZ-B/ESP32 skill to control WowWee MIP, enabling ESP32-Cam camera support and flexible battery-powered integration. Try it →
Resolved Resolved by mtiberia!
Uart Receive Query. Buffer Flush Command?
I am have a little issue with the below code.... I am attempting to read 3 different single byte return sensors on my new Create 2.... Now, it works perfectly if I read only one sensor in the repeatuntil loop. However if I do more than one read (like the code below).... the readings report back false... i.e. the bump sensor will indicate a bump when none occurred or the IR detect will indicate a bump instead of a indicating a close proximity of an object....
So am I daft and my code is wrong or does maybe the UART buffer need to be flushed after each read?
I am stumped....
Thanks guys
REPEATUNTIL(1=2)
  $x=0
  $y=0
  $z=0
  uartWrite(0,1,142,45) # Read Roomba IR sensors single byte
  sleep(10)
  IF (UARTAvailable(0,1)>0)
    $x=UARTRead(0,1,1)
    $x=GetByte($x)
  ENDIF
  sleep(10)
  uartWrite(0,1,142,7) #Roomba Bump and wheel drop sensor single byte
  sleep(10)
    $y=UARTRead(0,1,1)
    $y=GetByte($y)
  ENDIF
  sleep(10)
  uartWrite(0,1,142,58) # Stasis (Rommba moving forward) single byte
  sleep(10)
    $z=UARTRead(0,1,1)
    $z=GetByte($z)
  ENDIF
  print($x+" IR light object detected")
  print($y+" bump detected")
  print($z+" Is moving forward")
  sleep(200)
ENDREPEATUNTIL
Interesting try placing the initiate UART inside the loop. That should flush the buffer.
@mtiberia That didn't work either... the first read gives me the out of bounds of the array error.... This is the same problem I had way back when I first tried to do this with my old create 1... I was able to read single byte data but not anything with more than 1 byte.... This works on an Arduino and on my ancient Basic Atom Pro....
Either I am doing something wrong of you are correct the UART port doesn't work correctly on the EZB4
I just noticed an error in your code, I'm fighting the need for reading glasses, but try changing your code to the following.
if($rx=2) $RX_DATA = UARTRead(0, 1, $rx) $MSB=GetByteAt($RX_DATA,0)
$LSB=GetByteAt($RX_DATA,1)
That was my bad the above should work for you.
You're eyes are just fine... good catch dude....Can't believe I missed that as well....
Ok the code below seems to work, however if you don't have the uartinit() in the loop the buffer just continues to grow...
REPEATUNTIL(1=2)
 uartinit(0, 1, 115200) #used to flush the buffer
sleep(20)
   $RX_DATA=0
  uartWrite(0,1,142,22) # Volatge check
  sleep(10)
  $rx = UartAvailable(0, 1)
  print($rx+" bytes in the buffer")
  IF ($rx=2)
    $voltage=$LSB+(256*$MSB)
    print($voltage)
  ENDIF
  sleep(225)
ENDREPEATUNTIL
