Full Screen Video Player icon Full Screen Video Player — Fullscreen overlay video player controlled by ControlCommand: play/pause/resume/stop; ESC cancels playback and locks new playback until unpaused. Try it →
How are you using the command? Can you provide sample code?
Bear in mind, any command which fetches data must be assigned to a variable or used as part of an expression such as;
$x = UARTRead(0,0,10)
Or
IF(UARTREAD(0,0,10) = "true")
Or
Print("Data Received: " + UARTREAD(0,0,10))
Every ARC control and EZ-Script command has an example in the examples folder. The UART example is in EZ-Script Function Syntax\ and is named UART Peripheral. The scripts within the Example Project should help you understand how to use the commands.
It's a common mistake, I wrote a quick tutorial on getting data and using it in EZ-Script a while back which explains why just the command on it's own is meaningless.
For a better understanding, if you want it, have a read of this topic.
Glad that solved the problem:)
