EZ-Script Console icon EZ-Script Console — Real-time EZ-Script console for ARC: enter and execute single-line commands, view output, clear display, and recall history with UP/DOWN. Try it →
Ultrasonic Device
I can not get the ultrasonic device to detect an object, (wall ect). I have the ultrasonic device connect to trigger D21 echo D22 and even tried to swapping the trigger with the echo. If I look at the radar the distance is always 255. and I see two red spots that I think are the end points. I removed the device from the servo and tried not moving it, but held a moving object in front of it trying to see if there was a change on the radar screen. I set the distance to one and still did not get a change on the screen
Is there some kind of test I could perform to see if the device is working?
Please note I just received this developer kit and I'm use to the protocol of this website or how to communicate with fellow users. I'm not sure where to see my reply for thiis help message
I assume this is the old type ping that you need to use a voltage regulator with? The new one which is now in the online store here already has a 5V regulator on board the ping...
  1. If the ping constantly reads 255 then either it is wired incorrectly (which you checked) or...
  2. the voltage regulator that you need to use with it is either not outputting 5V or is not working/wired backwards etc or...
  3. The ping itself is defective...
Note If you use the old style ping without the voltage regulator you will destroy it...
5 volt regulator went bad. replaced 5 volt regulator and ok now. Thanks guys
