Roll Pitch Yaw icon Roll Pitch Yaw — Rotate and position camera or object with roll/pitch/yaw controls; save camera settings; bind or monitor a 3-value EZ-Script array for live rotation. Try it →
Ultrasonic Input Voltage From Battery Pack
I think that some of my trouble started after I got the second Ultrasonic sensor ,as I did not upgrade the battery pack (old radio shack plastic AA battery holder, rechargable 4 Nimh AA) which ran fine for 5 volts with 1 sensor. Now with 2 sensors sharing the same 5 volt pack, I think I may be getting low power current issue with both sensors , I think I will need a second 5 volt battery pack or could I now use the 7.4 volts directly out of the EZB4 since the voltage is divided by 2 sensors? Or will the 7.4 volts kill both sensors? I suck with electronics math, LOL!
#17
Going through all the video and sound recordings but this was the half second where something appeared and made the Help sound EVP at the same time with my Laptop losing control, It was see through like fog but the air was dry and nothing else there behind, just open field...and fairly large ,I saw it move right on top of the robot, so weird it had a dim blue glow. Hope I catch more like that!
Whoa! eek eek
That is an awesome pic!
Is that your robot right in the center of the blue fog?
Really awesome RR keep it going!;);)
#19
No this was the last picture it took before losing control. The camera was on the robot chest. I am going back tonight to check EMF levels and if any more voices come through on voice recording.Also found out that their was a guy that hanged himself in one of the trees out back so this makes 4 deaths known on this property. Anyway this went way off topic about sensor voltage:D
#20
You should make another thread for your findings.
I'll sub to your channel to be updated when you upload new footage.
How are the recordings going?
Will we have some footage with audio anytime soon?
#21
I will be putting all my findings into 1 video for youtube soon, I have a mountain of video/audio to go through still.:)
