Camera Snapshot icon Camera Snapshot — Save camera snapshots to 'My Robot Pictures' (Pictures folder), manual or timed (0-100s), and trigger programmatically via controlCommand. Try it →
Ultrasonic Radar Panel Bot keeps doing circles
Ultrasonic Radar Panel Bot Keeps Doing Circles
Hello everyone,
Im using the HC-SR04 , works well but when using the Radar it detects then bot move back and just keeps doing circles. I tried all different settings. The sensor is fixed not on a servo. What do you recommend?
Thank you all
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
Ultrasonic Radar by Synthiam
Ultrasonic on a servo sweeps 180°; radar shows distances and obstacles, integrates with movement panels for automatic avoidance, scriptable GetPing
Stops robot movement (no steering) when an EZB-connected ultrasonic sensor detects an object within a set range; integrates with scripting and paused polling.
Dual Hbridge by Synthiam
Two-channel Dual H-Bridge movement panel to control two DC motors (on/off) for forward, reverse, left, right via EZ-B digital ports; no PWM speed.
Yes good on sleep.
Shocked there is not a basic skill for Sonar. Such a great tool in the shed.
Unless it exist and I have not found it.
a few are there in the script help . and the pauze on/off . you have to look under "ping "
DJ -
Did you just make that skill? If so thank you Sir.
#37   — Edited
Issue resolved by new ARC skill.
Ultrasonic Collision Script
Thank you all, DJ and Nomad 6R
