Live Stream Receiver icon Live Stream Receiver — Play live web video and audio streams inside ARC from Chrome/Firefox, streaming directly to ARC camera control; network configuration may be needed. Try it →
Ultrasound, Ping And Object Avoidancec On The Ezb-V3
Richard, would you know what script the Object Avoidance was for the v3. I have One PING unit with One sharp IR. . that's it. I just want to find that little algorythm.
I used to know this site like the palm of my hand. But, I have forgotten a lot in the last many years.
I am down to one robot, Sally. I finally scraped up enough to get some eyes. I have the voice programmed the way I want it. And, I have the base running smooth. All I need now are some avoidance so she doesn't look stupid and run into walls like me.
God Bless! :-) MovieMaker
@Rich's ping roam uses one ping sensor, and does a pretty good job. You need to tweak the timing of the sleep steps after a turn command to match how quickly your robot takes to turn 90 degrees.
I forgot to ask, but, do you have a link to ping roam? I totally can't find it.
thanks, Mel
Nevermind. I managed to stumble upon it. Thank You anyway.
God Bless,
Mel
NP. I was just about to post the link. There are a few versions. 1.1.2 is stable, 1.2 is Alpha so you might run into some issues, but probably worth trying.
I think the Alpha of 1.2 runs OK but may need some tweaking. I was unable to test 1.2 with a physical robot since my test bot I made for this moved far too fast.
Either 1.1.2 or 1.2 should work but both will need some tweaking to suit your robot. Both should also be easily updatable to add more sensors, change the rotation of the single sensor, change sensors from PING to IR. 1.2 is documented and easier to adjust... every sub script is a separate script rather than a lot of goto/returns in one script.
I don't know what changes have been made to EZ-Robot and the EZ-Script syntax since writing either. You may find some errors with code if DJ has changed the syntax.
I have run 1.1.2 fairly recently without issues from syntax changes. My only issue is that my ping sensor is somewhat off-center on a Roli so does not have wide enough coverage, so would occasionally get stuck because the ping sensor didn't see the obstruction. I would add another one, but because I extended the arm length and added an LED headlight and laser diode, I am out of digital ports. I may swap out to IR sensors all around (I have one pointed down to prevent going over a step into my family room, and it works well - just no nice EZ-Bit enclosure. I may have someone 3D print one for me...)
Once EZ-Robot gets the compass working correctly on the 4in1 sensor, I plan to update the script to have the turns be x-degrees instead of x-milliseconds. I will post the update, with proper attribution to Rich for hte original code.
My setup is a single ping on a servo. It is the kind that also has a sharp IR underneath it. I have since developed a real problem. While installing the latest version of ARC, It came back with an error. It could not remove the older version. Now when I try to upgrade or downgrade, it tells me that the machine has an earlier version of ezb. I have hacked the register and removed anything having to do with ezb. But, it still tells me that a newer version is already installed.
RATS!
Mel
