Openai Chatgpt icon Openai Chatgpt — ChatGPT chatbot for robots with memory, image description, personality scripting, and voice conversation via OpenAI API Try it →
Unable To Install ARC
Hi,
I am new to this forum and just ordered by EZB V4. I have a Surface Pro 2 running windows 8.1 pro. I just tried to download the ARC for windows and am unable to install it. As soon as I double click the ARC Windows Installer Package (.msi) file, it shows the following error -
There is a problem with this Windows Installer Package. A DLL required for this install to complete could not be run. Contact your support personnel or package vendor.
I appreciate your guidance on resolving this so that I can start playing with the EZB v4.
Thanks, Saraj
Thanks Technopro:)
"There is a problem with this Windows Installer Package. A DLL required for this install to complete could not be run. Contact your support personnel or package vendor."
I had the exact same problem. The solution is to go into c:\users"username"\AppData\Local\ then right click on "temp" and choose "properies". Choose "security" --> edit --> add, and add the username you are using, and give yourself all rights. After that it'll work:)
Good luck!
