Conversational Menu icon Conversational Menu — Voice menu tree to navigate options and run scripts on ARC robots. Multi-level, customizable prompts, speech I/O, timeout and repeat/back. Try it →
Singapore
Unable to turn left and right (roli) and use EZ Say using ARC Mobile
Unable To Turn Left And Right (Roli) And Use EZ Say Using ARC Mobile
Hello,
As mentioned on the title, I am unable to turn the Roli left and right using the mobile application, yet I am able to do so using the system version. May I know why?
Also, I am unable to use the Say EZB block on the mobile function to enable the robots (JD, Siz, Roli) to say something. May I know the reason why?
Roli Rover by EZ-Robot
Roli Rover with Synthiam ARCx: drive with live video, control arms, follow faces, patrol, and program with Blockly or Python
i gess you mean by system pc ?on the mobile interface is an update button.but am gessing you have a bad download on you mobile, cause the command are not there.you can try delete it and redownload it.
