MMA7455 Accelerometer icon MMA7455 Accelerometer — I2C accelerometer for EZ-B robots, supplies IMU/acceleration data over the I2C interface. Try it →
Unhandled Exception Error Using Scan Tool
@DJ... I am getting an unhandled exception error when I use the scan tool.... I click scan and immediately I get the error.... ARC then stops responding... I get this on 2 of my PCs with the latest version of ARC (Nov 30).... I have re-installed and re-booted, no joy.... However on my ACER W3 tablet I have an older version of ARC (Aug 25/15) which has no issues with using the scan tool....
Here's a copy of the error... I can't use the scan tool on either of my main PCs with the latest release of ARC. However I have an ACER W3 with an earlier version of ARC (Aug 25) and the scan tool works fine...
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text ************** System.Net.Sockets.SocketException (0x80004005): Only one usage of each socket address (protocol/network address/port) is normally permitted at System.Net.Sockets.Socket.DoBind(EndPoint endPointSnapshot, SocketAddress socketAddress) at System.Net.Sockets.Socket.Bind(EndPoint localEP) at EZ_Builder.UCForms.FormConnectionScan.GWNL4xv5I5(Object , EventArgs ) at System.Windows.Forms.Form.OnLoad(EventArgs e) at System.Windows.Forms.Form.OnCreateControl() at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.WmShowWindow(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.Form.WmShowWindow(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.6.127.1 built by: NETFXREL3STAGE CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
EZ-Builder Assembly Version: 2015.8.9.0 Win32 Version: 2015.11.30.00 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/ARC/ARC.exe
PresentationCore Assembly Version: 4.0.0.0 Win32 Version: 4.6.127.1 built by: NETFXREL3STAGE CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
WindowsBase Assembly Version: 4.0.0.0 Win32 Version: 4.6.127.1 built by: NETFXREL3STAGE CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
System Assembly Version: 4.0.0.0 Win32 Version: 4.6.79.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.6.79.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.6.93.0 built by: NETFXREL2STAGE CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
EZ_B Assembly Version: 2015.7.28.0 Win32 Version: 2015.11.30.00 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/ARC/EZ_B.DLL
System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.6.79.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.6.79.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.6.79.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Speech Assembly Version: 4.0.0.0 Win32 Version: 4.6.79.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Speech/v4.0_4.0.0.0__31bf3856ad364e35/System.Speech.dll
EZ-RibbonMenu Assembly Version: 2015.7.3.0 Win32 Version: 2015.07.03.0 CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/ARC/EZ-RibbonMenu.DLL
System.Xaml Assembly Version: 4.0.0.0 Win32 Version: 4.6.127.1 built by: NETFXREL3STAGE CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
FFMPEG Assembly Version: 2013.8.13.0 Win32 Version: CodeBase: file:///C:/Program%20Files%20(x86)/EZ-Robot%20Inc/ARC/FFMPEG.DLL
Microsoft.GeneratedCode Assembly Version: 1.0.0.0 Win32 Version: 4.6.79.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Web.Services Assembly Version: 4.0.0.0 Win32 Version: 4.6.79.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Web.Services/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
Accessibility Assembly Version: 4.0.0.0 Win32 Version: 4.6.79.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled.
For example:
<configuration> <system.windows.forms jitDebugging="true" /> </configuration>
When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
Btw this is resolved in the recent update.
Thanks LOL.... I did know that, but I was waiting for you to post the release notes before I said anything....
Geez @DJ... busy day yesterday for you....:)
