Exosphere icon Exosphere — Telepresence and remote control for any robot with human-assisted tasks, video, audio, and AI training via ARC and mobile devices Try it →
Unity control lag with Camera Servo
Unity Control Lag With Camera Servo
I’m running an iRobot Roomba base in ARC, connected over USBTTL serial (COM4, 115200) using the iRobot Roomba Movement Panel. On top I have a 2DOF pan/tilt camera on an EZB v4 (D0/D1) and a Logitech C920 USB camera into the Windows laptop that runs ARC. I added the Single Camera servo Server skill so a Unity client can get the video and send servo positions.
Unity connects to the skill on localhost (using the port shown in the skill UI), video streams fine, and I’m sending two "virtual" servo channels (D2 = turn, D3 = throttle). In ARC I map those to the Movement Panel with a small JavaScript loop (below). It works, but two issues are blocking me:
  • If I pause/disable the Camera Device in ARC, servo updates from Unity stop completely, so I can’t drive without video.
  • When camera FPS dips (e.g., 320x240@15fps dropping to ~8-10fps under load), Roomba driving becomes bursty and lurches, as if servo updates are throttled to the camera frame rate.
Here’s the ARC JavaScript I’m using to translate the two virtual servos into movement commands:
while (true) {
  var x = GetServo("D2"); // turn
  var y = GetServo("D3"); // throttle
  var forward = (y - 90) / 90.0;
  var turn = (x - 90) / 90.0;
  if (Math.abs(forward) < 0.1 && Math.abs(turn) < 0.1) {
    Stop();
  } else {
    SetSpeed(Math.round(Math.min(100, Math.abs(forward) * 100)));
    if (forward > 0) { Forward(); } else if (forward < 0) { Reverse(); }
    if (Math.abs(turn) > 0.1) { if (turn > 0) { Right(); } else { Left(); } }
  Sleep(20);
I tried lowering camera resolution/FPS, moving the camera to another USB bus, and running Unity on a separate PC; the jitter still correlates to camera FPS. Is there a way to decouple servo transmission from the camera stream in Single Camera servo Server (or keep servo updates alive when the camera is paused), or should I use a different ARC skill/protocol for reliable Unity-to-Roomba driving?
Roomba by iRobot
Synthiam ARCx turns iRobot Roomba into a drivable robot with scripts, sensors, browser control, and AI-ready robotics skills.
Controller Dependant
Servos ✕
ADC ✕
Digital ✕
Movement Script by Synthiam
Trigger direction-specific scripts when ARC movement panels change; assign scripts per direction/stop, access direction and speed (JS/Python/EZ).
TCP video server for Unity clients to stream camera video and send servo positions to ARC for remote robot control
Yes - what you’re seeing is consistent with how the Single Camera servo Server skill is designed: the camera stream is the transport loop for servo updates. If the camera is paused/disabled, the servo side can stall too, and when FPS drops, servo updates can feel bursty because they’re effectively riding along with the video cadence.
What’s happening
  • Camera off / paused no video packets, so servo updates from Unity can stop.
  • Low FPS fewer update packets, so movement appears to "lurch."
  • Your current JavaScript loop is also polling servo state, which means it’s not an ideal way to make real-time drive commands feel smooth.
Best recommendation
For reliable Unity Roomba driving, use a separate control path for motion instead of tying driving to the camera servo server.
Good options
Option 1: Use ControlCommand() or movement commands directly
If Unity can send commands into ARC (via TCP, UDP, HTTP, or a custom plugin/skill), have it send:
  • forward
  • reverse
  • left
  • right
  • stop
Then let ARC’s Movement Panel handle the Roomba.
This is the cleanest approach because movement is designed to be global in ARC and does not need the camera stream.
Option 2: Build a custom robot skill
If you want a dedicated Unity bridge, the best long-term path is to create a robot skill that receives Unity’s joystick values independently of the camera.
That way:
  • camera can be on/off without affecting drive
  • servo updates can be sent at their own rate
  • movement can be smoothed and filtered
Create a skill here if needed: https://synthiam.com/Support/Create-Robot-Skill/Overview
Option 3: Send drive data through a protocol separate from video
For example:
  • UDP for joystick/motion updates
  • HTTP POST for discrete commands
  • TCP socket in a custom skill
This keeps camera load from impacting driving.
Why I wouldn’t use the current loop
Your ARC script is polling virtual servo values like this:
while (true) {
  if (Math.abs(forward) > 0.1) {
    Forward();
  } else if (forward < -0.1) {
    if (turn > 0) {
      Right();
    } else {
      Left();
  Sleep(20);
A better architecture is:
  • Unity sends joystick values directly to ARC
  • ARC stores them in variables or receives them in a skill
  • A movement script or control loop applies them continuously
  • Camera is only for video
What I’d suggest for ARC
If you want to stay simple:
Use a small custom skill or script receiver that accepts joystick values from Unity and writes them to ARC globals like:
  • $UnityTurn
  • $UnityThrottle
Then a JavaScript loop in ARC can read those and drive the Roomba.
Example ARC JavaScript pattern
while (true) {
  var x = getVar("$UnityTurn", "90");
  var y = getVar("$UnityThrottle", "90");
  var turn = (parseInt(x) - 90) / 90.0;
  var forward = (parseInt(y) - 90) / 90.0;
  if (forward > 0.1) {
    Movement.forward();
    Movement.reverse();
  } else if (turn > 0.1) {
    Movement.right();
  } else if (turn < -0.1) {
    Movement.left();
  } else {
    Movement.stop();
  sleep(20);
That keeps motion logic independent from the camera stream.
About the camera pause issue
If you specifically need video off but servo/motion still active, then Single Camera servo Server is the wrong transport for that use case because it couples both together.
My recommendation for your setup
Since you have:
  • Roomba base
  • EZB v4 pan/tilt
  • USB camera
  • Unity client
I’d do this:
  1. Keep Single Camera servo Server only for camera/video + pan/tilt
  2. Use a separate Unity-to-ARC channel for drive control
  3. Drive the Roomba through the Movement Panel
  4. Optionally create a small custom robot skill for the Unity input
Quick question
How is Unity currently sending those virtual servo values into ARC?
  • through the Single Camera servo Server only
  • through a separate TCP/UDP connection
  • or through an ARC script/plugin you wrote
If you tell me that part, I can suggest the best exact ARC-side setup and give you a concrete JavaScript or Python example.
