MPU6050 Accelerometer Gyro Temperature icon MPU6050 Accelerometer Gyro Temperature — Reads MPU6050 gyro, accelerometer and temperature via I2C, initializes and returns data on-demand to EZ-Script variables using ControlCommand RunOnce Try it →
Updated Needed For Script Help
Small fix/correction suggested for the "Script Help". The Script Help states:
IsConnected( boardIndex ) Returns TRUE or FALSE if the specified EZ-B board index is connected Example: $status = IsConnected(0)
It does not appear to actually return a value of TRUE/FALSE it returns a value of 1/0, where 1 means connected and 0 represents disconnected.
This leads me to a question on how to use "Print". In my code below the value for $status is printed (either a 1 or a 0 for connected for disconnected).
Print($status)
If I run this from the options (or edit) of a script and then select the console tab and run it, I see the printed output. Is there any other place I can see the printed output, or not so much? This makes me want a virtual LCD screen to print things too. :)
IF(IsConnected(0) = 1)
  $Status = "True"
Else
  $Status = "False"
EndIf
Pop that in a script in script manager somewhere and call it with ControlCommand each time you want to check status to save typing it each time.
Not sure if you wanted a work around or not but there it is anyway:)
P.S. Virtual LCD sounds awesome however since different LCD displays are controlled differently it may not be as useful as first thought. What I have done is resized the script control so it displays the correct number of characters and rows which works for the most part:)
Thank you Rich. I appreciate the work around.
In programming, this is the same for TRUE...
if ($x = true)
and
if ($x >= 1)
And this is also the same for FALSE...
if ($x = false)
and
if ($x = 0)
Remember, that TRUE and "TRUE" are no the same thing
