PTI Lidar Plugin icon PTI Lidar Plugin — Pineapple Technology Industries Capstone plugin adds a secretive LiDAR unit to ARC for distance measurement. Try it →
Please post the contents of the debug window. There is a copy button to copy the contents, and paste it in here:) Thanks!
Attempting connection to COM3 EZ-B reports EZ-B Firmware V8.5 Connected Usending ping Usending ping Usending bootloader Failed to load bootloader! Have you selected the correct EZ-B COM port? Use the Help menu option to view the online help and watch a video demonstration.
You are attempting to connect to your modem and not the ez-b. use the ez-b port that you wrote down, or remove the Bluetooth device and readd:)
Voila!
lol well ive tried what youve suggested and its asking for a pair number when i to updating my firmware
Press the menu option "Tutorials" from the top of this website. You will find videos for each step of using your EZ-Robot Complete Kit:) There are nearly 200 videos in the EZ-Robot series that helps you through everything.
Also, when you load the ARC Software - there is a Tutorial Animation that instructs you to follow. When using the Firmware, there is a HELP option that brings you to the Tutorial Section.:)
Dracula! Your problem Sucks!
I am a Dracula fan also.
