Sound Script (Ezb) icon Sound Script (Ezb) — Trigger a script when EZB audio plays, exposing live Min, Max and Avg audio-level variables for looped monitoring; stops when audio ends. Try it →
Upgrading Firmware Question
Hi I am new at this and need help from anyone with experience. I would appreciate some guidance. Below is the screen I get every time I try to upgrade the firmware.
I get connected and this is as far as it goes. I disconnect the EZ-B after a more than 15 minutes and start over only to get the same result. The progress bar fills to the end and then everything stops.
Please help. Casperbot
Firmware Updater Version: 2013.01.29.00 3/2/2013 11:13:35 AM - Begin
Attempting connection on COM6 EZ-B reports EZ-B Firmware V2 Connected
Welcome to EZ-Robot!:)
This is the first time you have used this EZ-B. After this upgrade, we recommend that you take a moment to view the tutorials at www.ez-robot.com/Tutorials. Nearly every question you have regarding EZ-Robot is answered in the Tutorials.
Press the HELP menu option to watch a video about this Firmware Upgrade process. Otherwise, press UPDATE when you are ready.
3/2/2013 11:15:42 AM - Sending bootloader Starting Boot Loader...
3/2/2013 11:15:51 AM - sending ping 3/2/2013 11:15:52 AM - sending ping 3/2/2013 11:15:54 AM - Sending bootloader I am EZ-B BootLoader. Gimmie Firmware!
3/2/2013 11:16:02 AM - Step 1 of 2) This process will take 2 minutes. The status bar will display progress.
3/2/2013 11:16:02 AM - Updating... (22,656 Bytes)
Look as if you are not using the Microsoft Bluetooth stack. Uninstall the Bluetooth that came with your computer. Third party Bluetooth programs rarely work. The tutorial page will help you:)
Thanks. I had a good look at what bluetooth stack I was using. I discovered that a "Toshiba Microsoft bluetooth stack", as Toshiba described it, was not a Microsoft native stack. At least the one on my lap top is not. I downloaded a Microsoft stack and everything went smooth with the firmware upgrade. I apologize for not digging deeper before calling for help.
Excellent! Your question will help others in the future:)
