Getrss icon Getrss — Fetch RSS via GetRSS command; populates $RSSSuccess, $RSSErrorMsg and arrays $RSSTitles, $RSSDescriptions, $RSSLinks, $RSSDates for scripts. Try it →
Use Android Mobile Joystick To Control Robot
Hello: I have been following EZ Robot for some time now. I am amazed at the progress you have made with this system. I am intrigued with the possibility of hosting EZ Build on a Raspberry Pi and controlling the bot with an Android device. I would like to use the Android mobile control Joystick to drive a Bot with a RPi as the EZB Host/Server. If I could send the JoyStick commands to the Bot as either serial or TCP/UDP messages I could intercept them (serial com or TCP/UDP) and convert them to the required format. So my question is ..How /where can I finde the command formats or content sent by the Android/mobile Joystick? Thanks for a great system and your assistance with this matter. G.Byron Brooks
Are you asking to use the existing mobile app to connect to ARC on the Raspberry Pi? Because that isn't possible. However, there might be an Android joystick app that can be used. Have you come across any android joystick apps? We could whip up a quick control to support the data from a joystick app.
