Waveshare Bus Servos icon Waveshare Bus Servos — Control Waveshare servos (TTL/RS485): set position & speed, release torque, read position. RTS option for converters; reverse-engineered protocol. Try it →
Can you be more specific?
The Script Console is a realtime script "command line" of sorts, so if you were to type Print("Hello World") it would output Hello World in the script console. The script console is the same as EZ-Script but instantly runs the command when typed.
What is it you are trying to achieve using the script console?
