Wii Remote icon Wii Remote — Control servos, movement panels and scripts via Wii Remote or mobile accelerometer; D-pad, buttons and Home-enabled accelerometer tracking. Try it →
Using Brushless Motors with ARC
Using Brushless Motors With ARC
just a question with this cycloidal gear, it can be used with these skills ? Sabertooth Movement Panel Brushless Motor Movement Panel Dual Hbridge W/PWM
Control brushless motor controllers (hoverboard-style) via EZ-B: configure direction, speed and optional brake ports for DIY robot movement.
Yes - brushless motors require a brushless motor controller, so they would not use:
  • Sabertooth Movement Panel
  • Dual H-Bridge w/PWM
Those two are for brushed DC motors only.
For brushless motors in ARC, use a skill like:
Important distinction
  • Brushed DC motor = uses an H-bridge / motor driver
  • Brushless motor = uses an ESC / brushless controller
If your cycloidal gear setup is being driven by a brushless motor, then yes, it can work in ARC as long as the controller is a brushless controller and the Movement Panel skill matches the hardware.
About the cycloidal gear
The gear mechanism itself doesn’t determine the ARC skill - the motor type and controller do. So ARC only cares about:
  • what motor is installed
  • how it is controlled
  • whether the skill supports that controller
Quick check
If you tell me:
  1. the exact motor model
  2. the controller/ESC model
  3. whether it’s single motor or dual motor
I can tell you exactly which ARC skill to use and how to wire/configure it.
