Cognitive Emotion icon Cognitive Emotion — Uses Microsoft Cognitive Emotion cloud to analyze camera images, returning emotion descriptions and confidence for speech/output (requires internet). Try it →
Using Dynamixel Servos With ARC
Hey, I was tossing it in my head for a while...but I did not ask this, because there is a solution already, and I chose to build my robot using a different brand of servos!
But now that there is a discussion, on how to integrate Dynamixel servos as easy as possible int ARC software, I just wanted to ask... Would it be possible, to modify the code of the plugin to work by just sending the servos instructions directly by using the LewanSoul BusLinker?
That way, there is no need to use any additional code running on a separate microcontroller...
I see the pros of a dedicated microcontroller...but the ease of use might be talking for this solution? Any thoughts on this?
https://www.amazon.com/LewanSoul-BusLinker-Debug-Board-LX-16A/dp/B073WRLJB2
Opencm 9.04 by Robotis
OpenCM 9.04 with Synthiam ARCx drives Dynamixel servos in a web browser for animations, scripts, AI and hardware I/O
USB
Servos 200
ADC ✕
Digital ✕
Lewansoul Servo by LewanSoul
Control LewanSoul LX-16A servos via ARC (EZ-B v4/IoTiny): assign virtual ports, read positions, set speeds, and enable continuous rotation.
Dynamixel by Robotis
Open-source ARC plugin to control Robotis Dynamixel servos (XL-320, AX-12, XL430) via EZ-B, Arduino or Robotis. Supports position, speed, accel.
