Using Ezb Hbridge To Control Rc Truck
I am looking to control a basic RC Truck using an HBridge from EZ-Robot. The RC truck is quite simple in that it has one motor for forward and reverse. It has another motor for left and right steering. With the regular RC Controller there is no PWM to control the speed going forward or reverse. My goal is to use the EZB controller along with a mobile app to control the RC Truck and add headlights, the EZB camera in the truck bed, etc.
My thought was to use the HBridge PWM Movement Panel along with the joystick pads in the mobile interface builder to control the truck motors to simulate the original RC Controller. I need to control the motors separately. It looks as if the EZB HBridge PWM Movement Panel is set up to control a left and right motor to give you the forward, reverse, left and right functions. This won't work in my case because there is one motor for forward/reverse and another for left/right.
I wanted to control the motors separately and not in conjunction with each and I have looked at the EZB HBridge PWM Movement Panel and the Joystick Pad in the Mobile Interface Builder to see if I could make them work like I want with no success.
Is there a way to do what I want with the existing Movement Panel and joystick pads and if not can the movement panel/joystick pad controls be modified to accommodate cases where one might want to control the motors individually? Ideally I would like to have one joystick in the mobile interface builder control the forward/reverse function with PWM and another joystick pad to control the left/right functions with no PWM required. Doesn't look like the existing HBridge PWM Movement Panel and Mobile Interface Builder in their current forms won't work. This is my view and I certainly could be wrong. Any thoughts on this matter would be much appreciated.
I think an HBridge PWM Movement Panel/Mobile Interface Joysticks that allow the motors connected the HBridge Hardware to be controlled individually would be useful not only for my application but also other applications. Again, any thoughts on this are much appreciated and other solutions are also welcome. :)
#25
Regarding the Movement Panel and pwm values, I noticed the valid range is from 0-100. Typically for an 8 bit value you would have a range from 0-255. This would give a finer range of pwm values. I assume that the values from 0-100 go from slowest to fastest, 0 being off and 100 being max speed. Would this be correct and why not 0-255. Just curious? Rick
#26
Hello Alan,
Just wondering if you had a chance to check out the SayEZB issue in my project using your android phones with version 6.0.1 software? Thanks for your efforts........Rick
#27
I'll be testing it out tonight. Making dinner now, so another hour or so.
edit: answered in wrong thread. Rick, see your bug report thread for my test results.
Here are some pictures (I think) of my lattest project. It is working quite well. I plan on adding a camera and the RGB Display. Also looking to add front headlights and rear lights.
Looks like maybe this was successfull. Rick
#30
Here is one more picture:
Rick
#31
Sorry it took so long for the pictures.
On the left (red circuit board) is the H bridge controller, and on the right (Green circuit board) is the voltage regulator for the 3x Ultrasonics sensors. The LED's are wire directly to the EZ-B, used signal wire (D14, D15) to turn them on and off with a simple script.
Quick breakdown of the pins assignments also in the demo project, D0 PWM Sterring D1 PWM Rear D2 Hbridge A1 D3 Hbridge A2 D4 Hbridge B1 D5 Hbridge B2 D6 Scan Trig White D7 Scan Echo Red D8 E-Stop Trig White D9 E-Stop Echo D10 Rear Trig White D11 Rear Echo Red D12 servo Y 1-71 D13 servo X 2-180 D14 Brake Light D15 Headlight
Picture below, try several time to remove the built in steering motor, but difficult to mount the servo without buying new stuffs (wanted to used what I had laying around) , so I tap into the original steering, not precise. Do not turn as sharp as I would like but for learning purposes does the job.
PJ,
Thanks much for the pictures ! I will probably add an ultrasonic sensor somewhere in the front of my truck. Just happy my truck is up and running....Take care....Rick
