MPU9150 Accelerometer, Gyro, Temperature, Compass icon MPU9150 Accelerometer, Gyro, Temperature, Compass — MPU9150 ARC control reads compass, gyro, accelerometer and temperature via I2C, initializes and sets EZ-Script variables on demand. Try it →
Using GetRSS data in JavaScript
Using Getrss Data In Javascript
I’ve got an OpenCM 9.04-C on USB with an XL-320 (ID 1) and ARC is talking to it fine with the Robotis DYNAMIXEL robot skill. I can jog the servo and run a simple wave motion, so the hardware/firmware side looks good on Windows.
I’m trying to pull an RSS feed and trigger a gesture + speak the latest headline. I added the GetRSS robot skill and can see items come in (its log shows fetched entries). In the Variables tab I also see $RSSTitles[0] populated after a query. But when I try to read those variables from a JavaScript skill, I’m getting empty values. Here’s the minimal JS I’m running:
ControlCommand("GetRSS", "https://news.google.com/rss/search?q=robotics";);
Sleep(2000);
var ok = getVar("$RSSSuccess");
var t0 = getVar("$RSSTitles[0]");
print("ok=" + ok + " t0=" + t0);
Most runs print ok=1 t0= (blank). Occasionally I’ll see t0 filled, but it’s inconsistent even though the Variables tab shows $RSSTitles[0] has a value right after the same query. I’ve tried longer Sleeps (up to 5s), calling the ControlCommand from a separate Script control first, and refreshing variables. Same behavior. I was planning to match keywords and then call my DYNAMIXEL servo move from JS, but I’m blocked on reliably accessing the arrays.
  • Is the ControlCommand syntax correct for GetRSS from JavaScript, or should there be a verb like "Get" before the URL?
  • In JavaScript, is getVar("$RSSTitles[0]") the right way to index the array, or do I need a different pattern to read array elements from global variables?
  • What’s the recommended way to wait until GetRSS is fully populated before reading so I can trigger my XL-320 gesture reliably?
What is the correct ControlCommand syntax and the reliable JavaScript approach to wait for and read $RSSTitles/$RSSDescriptions from GetRSS so my OpenCM 9.04-C controlled XL-320 can react to new feed items?
Opencm 9.04 by Robotis
OpenCM 9.04 with Synthiam ARCx drives Dynamixel servos in a web browser for animations, scripts, AI and hardware I/O
USB
Servos 200
ADC ✕
Digital ✕
Servo Script by Synthiam
Bind scripts to servo moves (V1-V99); triggers on position/speed/accel changes and provides ports, positions and speeds arrays for custom control.
Getrss by Synthiam
Fetch RSS via GetRSS command; populates $RSSSuccess, $RSSErrorMsg and arrays $RSSTitles, $RSSDescriptions, $RSSLinks, $RSSDates for scripts.
Yes - there are two issues in your example:
  1. ControlCommand() syntax for GetRSS
  2. How to reliably wait for the feed data before reading the global arrays
Correct ControlCommand() syntax
For the GetRSS robot skill, the command is:
ControlCommand("GetRSS", "get", "https://news.google.com/rss/search?q=robotics";);
So yes, it does need the verb "get" before the URL.
Your current line:
is missing the command name.
Reading array variables in JavaScript
Yes, this is the correct pattern:
That is the right way to access the first item of the array in ARC JavaScript.
If you want to be safe, you can also check the array directly:
var titles = getVar("$RSSTitles");
print(titles[0]);
That often makes debugging easier because you can inspect the whole array.
Why you’re seeing blank values
ControlCommand() is non-blocking, so the script continues immediately after sending the command.
That means this:
Sleep(2000);
is still a race condition if the feed takes longer than expected or if ARC hasn’t updated the globals yet.
Also, RSS fetching is network-dependent, so timing can vary.
Reliable way to wait for GetRSS data
The most reliable approach is:
  1. Send the get command
  2. Wait until $RSSSuccess is populated
  3. Then read the array values
Here’s a safer JavaScript pattern:
var timeoutMs = 10000;
var start = new Date().getTime();
while (true) {
  var successExists = varExists("$RSSSuccess");
  if (successExists) {
    var ok = getVar("$RSSSuccess", 0);
    if (ok == 1) {
      break;
  if ((new Date().getTime() - start) > timeoutMs) {
    print("Timed out waiting for RSS");
    return;
  sleep(100);
var title = getVar("$RSSTitles[0]", "");
var desc = getVar("$RSSDescriptions[0]", "");
print("title=" + title);
print("desc=" + desc);
Even better: read the array after success
If you want the most consistent result, read the array object after the request completes:
while (!varExists("$RSSSuccess") || getVar("$RSSSuccess", 0) != 1) {
    return;
  sleep(100);
var descriptions = getVar("$RSSDescriptions");
if (titles && titles.length > 0) {
  print("Latest title: " + titles[0]);
  print("Latest desc: " + descriptions[0]);
Triggering your XL-320 gesture
Once you have the text, you can match keywords and then move your DYNAMIXEL servo. Since you already have the OpenCM 9.04-C working with ARC’s Robotis DYNAMIXEL skill, you can just call the servo/motion commands from the same script after the RSS values are ready.
Example:
if (title.toLowerCase().indexOf("robot") != -1) {
  print("Robot keyword found. Triggering gesture.");
  // Example servo movement
  Servo.setPosition(v1, 120);
  sleep(500);
  Servo.setPosition(v1, 90);
  Audio.say(title);
If your XL-320 is bound through the DYNAMIXEL skill, just make sure you’re using the correct virtual servo port for that servo.
Best practice for this case
For this workflow, I’d recommend:
  • Use ControlCommand("GetRSS", "get", url)
  • Wait on $RSSSuccess
  • Read $RSSTitles and $RSSDescriptions
  • Then trigger your servo gesture and speech
One more tip
If you’re doing a lot of scripting like this in ARC, the built-in AI Assistant can help rewrite and debug your JavaScript directly in the editor: https://synthiam.com/Products/AI-Assistant
If you want, I can write you a complete ARC JavaScript example that:
  • fetches the RSS feed,
  • waits reliably,
  • checks the headline for keywords,
  • speaks it,
  • and triggers an XL-320 gesture.
