RGB Animator icon RGB Animator — Create custom animations for JD Humanoid's 18 RGB Eyes LEDs via I2C - per-LED color frames, transitions, pauses, scripting and real-time preview. Try it →
Twitter
Using OpenAI Skill with other products
Using Openai Skill With Other Products
OK great I noticed GPT4o says give me any image in any format and I will work it out where everyone else wants base64
from openai import OpenAI
client = OpenAI()
response = client.chat.completions.create(
  model="gpt-4o",
  messages=[
      "role": "user",
      "content": [
        {"type": "text", "text": "What’s in this image?"},
          "type": "image_url",
          "image_url": {
            "url": "https://upload.wikimedia.org/wikipedia/commons/thumb/d/dd/Gfp-wisconsin-madison-the-nature-boardwalk.jpg/2560px-Gfp-wisconsin-madison-the-nature-boardwalk.jpg";,
            "detail": "high"
  max_tokens=300,
print(response.choices[0].message.content)
Generate or edit images with OpenAI GPT Image from text or camera frames, with save and programmatic control commands.
ChatGPT chatbot for robots with memory, image description, personality scripting, and voice conversation via OpenAI API
Control robot arms with inverse and forward kinematics, converting X/Y/Z positions into joint motion and reporting end-effector location.
#25
Don’t forget the robot skills are open source. I don’t think ppl look at GitHub or follow the link. If something isn’t open then I post it. Usually it’s a pain to maintain the GitHub repo when most of our users have no interest in programming - and I support that. I don’t know why someone should need to program to make a robot shrug I mean, you don’t need to program to do anything else with a computer.
Twitter
#26
Please don't get me wrong, the last thing I want is for ARC to be open source and I do appreciate the skills are open source.  As I mentioned lots of challenges with open source including no support.  If I said this doesn't work with my open source models and ARC was free open source you would probably have said go suck a lemon, instead you opened a new thread as a support ticket and said lets get this working.  SUPER HAPPY CUSTOMER.
#27
@DJ, I get what you say. When I found your platform ARC years ago I was thrilled that I would not have to learn how to write code to get my robot to work the way I wanted. I thought I could just build my robot with my hands and do some simple EZ Scripting to get it to move and talk a little. After I got into EZ Script I realized how much it could do and how easy it was to understand. I realized my robot to do more but I found that I really did have to learn 'a little more" code to get it to act the way I wanted. I did the extra work of learning more about EZ Script and was amazed how my robot came to life.
I'm very grateful that your creation, EZ Script and ARC (now ARC), was out there when I needed it. It gave me the courage to do more and push my boundaries. I do know that your creation has tons of lines of scripting behind the EZ Commands and Skills in ARC that made my simple lines of EZ Script work. Now that I'm learning and working with Javascript so I can move on to ARCx, I can really appreacheate what must be going on behind the curtain of the old ARC and now ARC.
As a footnote, after learning enough Javascript to get me going, I've converted all my EZ Scripts over in preparation for ARCx. I've moved on to the more powerful (Your words DJ) Javascript and am very happy I did. A lot of the robot performance bugs I've been putting up with over the years are now gone. Not because EZ Script was at fault but because I was able to streamline my scripts and learn how they really run and affect my robot.
#28
Ah okay I see both sides of your perspectives. Dave, good news is the ability to "code" in ARCx isn’t removed. It’s assisted by ai. Meaning you can ask Athena to help write code in the editor.
regarding what nink wants to do - such as the weed killer robot. It’ll be easier with ARCx than arc. You can do that today with arc. You’d simply need to be good at prompt engineering.
such as defining the abilities in the prompt for the robot to move and identify. You would also need to provide an updated time stamp on every query so it knows when things happen and time between.
I don’t think ppl realize how powerful the gpt skill is today on its own. All you have to do is give it instructions in a prompt. And in response perform the actions it suggests. Rinse repeat:)
