Maestro Servo Controller icon Maestro Servo Controller — USB control for Pololu Maestro (6/12/18/24) via ARC Vx ports. Maps Vx to Maestro channels; supports position, speed, acceleration, release. Try it →
Using Seeed Studio Respeaker 2 Mics Pi Hat On A Raspberry Pi Zero
Hello,
I'm wondering if I could use the microphone on the Respeaker 2 mics pi hat (https://wiki.seeedstudio.com/ReSpeaker_2_Mics_Pi_HAT_Raspberry/) on a Raspbery Pi Zero. So far I can only find information on using microphones on the platform running ARC. If there are ways - how do I pass the recorded audio file through speech recognition? Thanks.
Raspberry Pi by Pi Foundation
Synthiam ARCx runs natively on Raspberry Pi 4/5, controlling robots via browser with EZB controllers, vision, speech and scripting.
Servos ✕
ADC ✕
Digital ✕
Hmmmm that’s an interesting question. I’m guessing the easiest way would be to link the two devices as a Bluetooth input device. So set the raspberry pi’s Bluetooth to be broadcasting as a microphone input device. Then add it to the ARC device’s Bluetooth. Finally, set the pi to pass through all mic input out the Bluetooth using the mixer.
Oh and I just thought of another way that would require more work. You could create a robot skill that has a tcp listener. All data from the tcp stream gets pumped into the input device mixer.
then, on the pi you can pipe the wav audio from the microphone into nc (netcat) which is set to connect to the ARC robot skill ip and tcp port
