Joystick (Direct Input) icon Joystick (Direct Input) — DirectInput joystick control for ARC: drive movement panels, control servos, assign button scripts, variable speed and rumble feedback. Try it →
Using Servo Speed
Using Servo Speed
Hi All, I've put together a script and I need some help refining it a little. When you say hands-up, my robot lifts up both arms, turns his head slowly left to right and then puts his arms down.
What I want to do is use servospeed to make him put one arm down slowly and then the other. I managed to use it ok with his head movements (beginners luck!) but I'm having issues with the arms. Everytime I try to string together a script to do the action above, his arms either move slowly for a very short time and then stop, or they just move at normal speed. Any advice?
I have put the script into the EZ Cloud / examples / handss up!
I also put togethera youtube clip so you can see what I mean:
Very cool, thanks for adding your work to the cloud...
Cool man ! Thnxs for sharing it with all of us;)
