Can you use the Oculus Rift plugin for JD with another headset? In this case a OSVR HDK 2 VR.
bmcnamee1
— Edited
4 Participants
EZB Connection
— Connects EZ-B I/O controllers to ARC via COM or IP (5 connections). Supports init scripts, battery monitoring, TCP/EZ-Script server and serial/I2C.
I'm not sure. I don't know what that is or if it'll work. Oculus really dropped the ball on driver support across versions. Have you tried the plugin? If you can connect to it and see the camera, that means it's working. You don't need a jd to test it. Simply download the ARC software and configure the plugin and use the camera on your laptop.
I keep trying the plug in but it won't work for me. Was so disappointed.
@AvatarX: What model and version you have ?
Ptp, I wonder if there’s a way to make a unity program that connects to ARC for these headsets. It seems there’s no good library that unites the vive oculus and windows mixed reality.
But a unity program released for steam vr would do the trick
I've got EZ-B v4 and consumer version of Oculus.
And a unity program would be incredible. I'm a total novice here but I'd love to see an Avatar style tele presence robot.
@AvatarX follow this thread....
https://synthiam.com/Community/Questions/11135
