Translate icon Translate — Translate text via Microsoft Translator (auto-detect); EZ-B plugin stores translated and detected language variables. Requires Azure key. Try it →
Using Touch Pad On Mobile Interface
OK, I'm just not getting it. But looking over the controls in Mobile builder I do not see a control for touch pad even though it says its supported. Could someone tell me how the heck I set it up and what controls to use?
Thanks in advance.
If its future feature....ughhh
@fxrtst.
You can use the servo touch pad control on the mobile interface. On the interface, add a button like the ABC button, and when you edit the script find "show controls" in the Cheat Sheet and then the ControlCommand() for showcontrol("Servo pad" ) and save it. Then re-save it to the cloud.
Once you open up the mobile app on your phone/tablet and updated your projects, open your project, press the button you added containing the "show servo pad" script, and a new window pops up with the touchpad which you will be able to use.
Hope that helps, and if you need any more help, just shout. :)
Thank you Steve!
No worries.;)
Hey Steve,
Just getting around to trying this out and I don't see a ControlCommand for showcontrol servo pad...I'm using the latest...am I still missing something?
Ok i think I got it set up correctly, except inside EZ mobile, says 'this is not yet implemented' fingerpad.
