Camera Snapshot icon Camera Snapshot — Save camera snapshots to 'My Robot Pictures' (Pictures folder), manual or timed (0-100s), and trigger programmatically via controlCommand. Try it →
DJ thats not what he is looking for ,RICH is using it as a switch ,to amplify that signal you need a non inverting op amp circuit with a gain of of 142.85 ,witch is a simple circuit,set it for 100 to 200 gain and with a pot you can adjust it.
I guess you need a circuit i can easy make a schematic or do a seach on the internet for (non inverting op amp circuit),just need a single op amp and 3 resistors.
Can do it with a transistor only it little harder with that much gain needed
TIP122 is a power switching darlington used mostly as a switch
You would like to use the current sensor as a switch, correct?
