Using Wifi , 3g And 4g Data Stick , Endless Range
Using Wifi , 3G And 4G Data Stick , Endless Range
Ok I picked up.three.of.these for 99 cents each but usually tmobile sells them for 40 . Up to.21 mb connection. Not.sure how.it could be direct wired to ezb but for those.with micro computer, android or mini itx you can connect through USB.
Having a onboard itx I could access the control panel over.the web or remote desktop. Having.the second data stick for the tablet means I don't need to rely.on local networking or having a WiFi router.nearby.
jstarne1 You can find more deals ! :)
Was that a compliment? Lol. You can do a dollar a say.unlimited plan or 30 monthly data.plan so there are flexible.no contract options.
NO, NO, NO, you're going the wrong way, It may be a good device but building a bot ( and maybe an expensive bot ) and then basically renting time so that you can use your own bot is ( in my mind ) ludicrous! I want to build my bots for my use first and not with a data plan ! sheesh
eek
I work for a cell company so to me its practical. I only pay ten bucks for all the data I need:)
I guess in-away I will be paying to use my bots here in Canada, Shaw Cable is expanding their network with a free WiFi service in major cities if you are a home service customer, I pay for home-use sooooooo that means I will be paying to use my own bot if I use WiFi control.
True , either way u paid lol
