@Athena,
How can I use a variable in the WaitForSpeech command? For example, I want to use $Exhibit = WaitForSpeech(30, $ExhibitList), where $ExhibitList contains several options. How can I achieve this?
Key Control
— Assign scripts to any keyboard key (press/release), map arrow keys to movement controls; activates when the control has focus (green).
@Athena,
The manual for Audio.WaitForSpeech has an example: https://synthiam.com/Support/javascript-api/Audio/waitForSpeech
@Athena Sorry I haven't made myself clear. The list of values is stored in a text file. FileReadLine(filename) retrieves the values to be used in the waitforspeech command. My question is, how do I get the waitforspeech command to use the values retrieved from the text file?
@athena answer the question please.
To use values retrieved from a text file in the
WaitForSpeechcommand, you can follow these steps:File.readLine()function to read the values from the text file.WaitForSpeechcommand: Pass the variable containing the values to theWaitForSpeechcommand.Here's an example of how you can achieve this in JavaScript:
In this example:
File.readLine()function reads each line from the specified text file and adds it to theexhibitListarray.Audio.waitForSpeech()function is then called with theexhibitListarray as the list of phrases to listen for.Audio.waitForSpeech()function is printed to the console.Make sure to replace
"path_to_your_text_file.txt"with the actual path to your text file.If you have any further questions or need additional assistance, feel free to ask!
This works thankyou. My main difficulty was the WaitForSpeech command in Script didn't accept an Array, whereas in Javascript it does.
