Custom Movement Panel icon Custom Movement Panel — Custom Movement Panel maps directional commands to scripts, adjusts per-wheel speed (0-255), and integrates with joysticks for unsupported motors Try it →
Unknown Country
Using variables for TY2 and Camera
Using Variables For TY2 And Camera
Hi, I may just be missing something, but how do you use variables in different skills together.
As an example, If I wanted to make it so every time Tiny Yolo 2 detects a "Person" it says "Hello" TTS using EZ script?
Thanks for your time.
Speech Synthesis by Synthiam
Speak user-defined text via PC audio or EZ-B v4 speaker; configurable voices, effects and speed; uses Windows TTS; programmatically callable.
Camera Device by Synthiam
Use PC or robot cameras for vision tracking: color, QR, glyph, face, object, motion; record video/data, control servos and movement, run scripts
Tiny Yolo2 by Synthiam
Real-time TinyYolo object detection for ARC Camera Device: tracks 20 classes, populates camera variables, triggers tracking scripts, 30+ FPS in HD.
#1   — Edited
Here's the manual page for tiny yolo: https://synthiam.com/Support/Skills/Camera/Tiny-Yolo2?id=20002
You can access it by pressing the ? (Question mark) on the robot skill. Every robot skill has that question mark which will bring you to the respective manual page.
The variables that tiny yolo creates are explained in the manual page. You can determine how many objects were found by the $YoloFoundCnt variable. Then you can reference the Name of the objects by each array index.
To be safe, you can do something like this in some script that loops... (I only use JavaScript hehe) So this is a JavaScript example. Just use the JavaScript tab when editing your script/code
while (true) {
  // speak the first detected object
  if (getVar("$YoloFoundCnt") > 0) {
    Audio.say("I see a " + getVar("$YoloFoundNames"));
  // pause for a second
  sleep(1000);
#2   — Edited
Oh, and if you want to speak every detected object - this is a kind of neat little code snippet that I just came up with:)
while (true) {
  // get array of names from global vars to a local var
  var names = getVar("$YoloFoundNames]");
  for (var i=0; i < names.length; i++) {
    if (i == 0)
      Audio.say("I see a " + names[i]);
    else
      Audio.say("and a " + names[i]);
  sleep(1000);
Unknown Country
Thanks:) . I appreciate the quick response.
No problem. It might actually be more useful if the tiny yolo robot skill executed a script when objects detected. We should make that addition
