Robotis Openmanipulatorx icon Robotis Openmanipulatorx — Inverse kinematics for Robotis OpenManipulatorX: compute joint angles and MoveTo 3D (cm) positions, supports camera-to-CM mapping for pick-and-place. Try it →
V4 - Chimes, Voices And Sounds
Is there any way (short of removing the speaker) to turn down or off the Chimes, voices and sounds that come out of the V4 anytime it connects, powers up or encounters any other event? While being helpful they kinda get in the way of the motif of classic robot recreation.
No - I thought about it but due to the Wi-Fi and software complexity of the EZ-B v4, turning it off would be impossible to diagnose hardware and connection issues. The only time you should hear a chime is on boot-up, disconnect, connect or connection error (if in client mode).
There are other very important messages - such as battery low and communication errors.
