TCP Clients icon TCP Clients — Monitor incoming TCP Server connections when TCP Server is enabled under Connection > Config; view and track live connections. Try it →
VB Tutorial #1 - Getting Started
Visual Basic Tutorial 1 - Getting Started While assumptions are not generally a good thing, I am going to start this tutorial project by assuming that the reader has a copy of VB Express and that you have at least a passing acquaintance with it and are comfortable using its IDE. If not, then please get a copy of VB Express (a free copy is available from Microsoft) and go through it's tutorials to become familiar with terms, procedures, etc. As well, I assume you have downloaded the EZ SDK from the EZ-Robot website and have installed it and know where the DLL has been put. 1.1 The first thing you need to is to get VB to recognize the EZ module. Follow these steps:
  1. Start up VB with a new project; call it whatever you would like say like MyProject. It should be a Windows Form Application. This will produce a form called appropriately enough Form1. Feel free to change this name if you like as well as any of the form's properties. (See why I assumed you knew VB already!!).
  2. Now we will add the EZ controls to the Toolbox. If the Toolbox is not showing then use View Other Windows Toolbox to display it. Right Click on the Toolbox. A dropdown menu should appear; select the Add Tab. A new entry in the Toolbox should show up where you can enter the name EZ-B or some other name of your liking. Now highlight the EZ-B tab and Right Click. From the dropdown menu, select Choose Items. A Choose Toolbox Items form should be displayed. Browse to where you put the EZ-B DLL from the SDK and press Enter. The Choose Toolbox Items form will now have 2 new entries; EZB and EZ_B Connect1. Select both items by checking the check boxes on the left and press the OK button. The Choose Toolbox Items form will close and the Toolbox should now have 3 new entries under the EZ-B entry. They are: Pointer EZB EZB_Connect
1.2 Now for your first program. Well it's not really a true program but it will actually do something and an important something as well. We will get the PC to talk to the EZ module.
1.2.1 Go the Toolbox and double click on the EZB_Connect. This will put a special EZ control on the form. This control will contain a button labelled Connect, a label which should default to Auto and another button, this one labelled Debug. You can move the control around to wherever you would like on the form, however, the top left corner is a good place for now.
1.2.2. Now for the fun stuff. Your program is ready to run. All you need to do is attach power to your EZ module and set up the Bluetooth connection. Details in the Getting Started instructions that came with your EZ module work fine. Once you attach power to the module, the LED will start flashing. Run your program by pressing the F5 key, press the Connect button and the Connect button will dim for a while. In a few seconds, the LED on the module stop flashing and the Connect button will change to Disconnect.
1.2.3. If all went well, your program will control whether or not your PC and the EZ module talk to each other. The next tutorial will actually write some code that will let you do something useful.
This is great!!! Thank you!:D
I'm on a steep learning curve so this is very helpful can't wait for #2
It seems I have some problems with my very first step. I double click EZB_Connect to add it to the form. Do I need to add something to the code?
System.InvalidOperationException was unhandled
  Message=An error occurred creating the form. See Exception.InnerException for details.  The error is: Mixed mode assembly is built against version 'v1.1.4322' of the runtime and cannot be loaded in the 4.0 runtime without additional configuration information.
  Source=WindowsApplication1
  StackTrace:
       at WindowsApplication1.My.MyProject.MyForms.Create__Instance__[T](T Instance) in 17d14f5c-a337-4978-8281-53493378c1071.vb:line 190
       at WindowsApplication1.My.MyProject.MyForms.get_Form1()
       at WindowsApplication1.My.MyApplication.OnCreateMainForm() in trihoufs1users$zzhangMy DocumentsVisual Studio 2010ProjectsWindowsApplication1WindowsApplication1My ProjectApplication.Designer.vb:line 35
       at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnRun()
       at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel()
       at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(String[] commandLine)
       at WindowsApplication1.My.MyApplication.Main(String[] Args) in 17d14f5c-a337-4978-8281-53493378c1071.vb:line 81
       at System.AppDomain._nExecuteAssembly(RuntimeAssembly assembly, String[] args)
       at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
       at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
       at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
       at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean ignoreSyncCtx)
       at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
       at System.Threading.ThreadHelper.ThreadStart()
  InnerException: System.IO.FileLoadException
       Message=Mixed mode assembly is built against version 'v1.1.4322' of the runtime and cannot be loaded in the 4.0 runtime without additional configuration information.
       Source=EZ_B
       StackTrace:
            at EZ_B.EZB.init()
            at EZ_B.EZB..ctor()
            at EZ_B.EZB_Connect..ctor()
            at WindowsApplication1.Form1.InitializeComponent() in trihoufs1users$zzhangMy DocumentsVisual Studio 2010ProjectsWindowsApplication1WindowsApplication1Form1.Designer.vb:line 25
            at WindowsApplication1.Form1..ctor()
       InnerException:
Netherlands
So i can see your missing dot net 3,5.
But if your at this stage, and you fix this by installing dot net 3,5 your next error will be lock. Read the readme in the sdk for the rest of the info.
I solve it by adding some code to the applications config.
Check it here.
My bad, forgot to check Readme.txt
So many problems using VS2010, even hot keys got changed. "Fix: Disable the loader lock MDA. Debug/Exceptions (ctrl-D, E), Open the Managed Debugging Assistants tree node and uncheck Loader Lock." Now it is ctrl+Alt+E
Thank you Pabi!o.
ZZ
hi I am using vb express 2008 on windows 7
I get this fare as this then get error
  1. Now we will add the EZ controls to the Toolbox. If the Toolbox is not showing then use View Other Windows Toolbox to display it. Right Click on the Toolbox. A dropdown menu should appear; select the Add Tab. A new entry in the Toolbox should show up where you can enter the name EZ-B or some other name of your liking. Now highlight the EZ-B tab and Right Click. From the dropdown menu, select Choose Items. A Choose Toolbox Items form should be displayed.
my location (C:\EZ-SDK\DLL) what do i click on
hi i fixed the problem:) it now is all working ok:)
hi now i get and error Warning 1 Referenced assembly '......\EZ-B SDK Windows\EZ-SDK\DLL\EZ_B.dll' targets a different processor than the application. myprojectX
