Debug icon Debug — Central ARC debug window routing logs; shows UTC date/time, Windows/ARC/skill/hardware info, version/settings, with copy and clear. Try it →
yes. You can add a variable watcher in the ARC software. Variables are global.
All variables are global, i.e. if one script sets a variable all other scripts will see that variable.
I use multiple scripts running at the same time. I have one which checks the voltage of a LiPo battery through the ADC ports, another which monitors the current through the ADC port and a few others which set/alter/monitor variables for moods.
I then have another script for the LCD display which outputs the variables to the display.
That's cool. I was hoping that would be the case.:)
One other quick question, in the mobile app Is there a way to have a button call up another menu or screen?
You bet! The ez script manual reads...
ShowControl( ControlName ) Used for mobile devices and the Interface Builder only, this command will open the specified control into the foreground. Example: ShowControl(Wii Remote)
ShowDesktop( desktopNumber ) Shows the specified virtual desktop. The desktop number is 1, 2 or 3. Example: ShowDesktop(1)
Although keep in mind that you can only show desktop #1 on mobile.
