Script icon Script — Multi-language ARC Script: build, run and debug Blockly, JavaScript, EZ-Script or Python with Intellisense, run/save/load and Roboscratch support Try it →
Resolved Resolved by ptp!
Vex Optical Shaft Encoder With A Kangaroo Board
Tonight I installed the vex shaft optical encoders on the inside shaft the wheels go on. I had to drill out the encoder wheel to fit the shaft and disassembled the encoder wheel and optics to mount on the metal gearbox, I also had to cut back the green plastic fins so it did not catch the encoder optics. I hope it works using the kangaroo board? The vex encoder has 2 red positive 2 grounds and 2 signal wires. I am thinking the 2 signal wires would go to A&b on the kangaroo but I m not exactly sure as the vex encoder document is not that great. https://www.vexrobotics.com/276-2156.html
I think one of the 2 signal wires would attach to A&B on the Kangaroo board but I would like to know before I connect them
Has or does and one know?
Cheers
I don't have one, but from the existent documentation the encoder is a Quadrature encoder, and has 2 phases (3 wires) each if you want to use it as Single Phase too. From the pictures both white cables are the Phase wires (A&B).
Thanks PTP I will give it a try
