Maestro Servo Controller icon Maestro Servo Controller — USB control for Pololu Maestro (6/12/18/24) via ARC Vx ports. Maps Vx to Maestro channels; supports position, speed, acceleration, release. Try it →
The camera can be focused, see https://synthiam.com/Community/Tutorials/41
However, be aware that if you are using it to record video, the quality will not match a decent web cam. It is designed for good object tracking and recognition, which requires different qualities than good visual video. It should be focused, but contrast and color rendition may not look like you expect.
There is no need to run 640x480 - use the default value as specified in your robot's project. To find out more, every control has a ? (question mark) next to the X (close) button. In this case, press the ? question mark on the Camera Control to view the manual page where you will find information regarding video resolutions and what that means to vision processing and recognition. Here's a direct link: https://synthiam.com/Tutorials/Help.aspx?id=80
