here a pic from telenet serversmtp.
smtp.telenet.be is clearly your smtp server name per them. So change the server name back to that and keep it that. Keep the port 587.
Try keeping the SSL checked as well. My concern is TLS which is close to SSL but not 100% the same. This might prevent it from authenticating correctly, it might not be possible with your email service.
Patrick, I assume you have your email password entered and it is just cleared out for the screen shot to share publically, correct? And I assume you are not loosing internet connection when trying this (just covering all the bases)?
If it keeps failing my best guess would be the TLS native cryptographic protocols from telenet.be is not compatible and I would recommend setting up a free email with a service like Yahoo! that has a known functional smtp interface.
justin
yes i cover up my password.i do have another mail adres with a .com
from gmail.my internet stays good.
joepie its working.needs some audio do,would cool.
wow jd is disconnected but he still sends pic to my mail?
#38
Glad to hear you got it working!
so how does it stop taking only one pic ?
#40
Patrick, put your thinking hat on. How does anything else stop in ARC?
If you are running this code:
:start
ControlCommand("Camera", CameraMotionTrackingEnable)
#center camera on object
if($Cameraistracking = 1)
sleep(500)
ControlCommand("Camera", CameraSnapshot)
ControlCommand("SMTP Client", SendImage, "Camera", "your email address here", "your name here", "Motion detected", "Hey Bob, this is InMoov. I have detected motion in the shop. Here's a picture of what I saw.")# you can change this to say what ever you want
Sleep(2000)
ControlCommand("Camera", CameraMotionTrackingDisable)
endif
sleep(10000)
goto(start)
Your answer is to stop the script. Come on, with your thinking hat on I know you had to have known that.
