Sound Movement icon Sound Movement — Stereo mic sound localization triggers left/right scripts to control robot movement, enabling directional responses (turn/move) to audio. Try it →
View Built In Scripts
Is there any way to look at how the script for camera tracking was written by Dj? I can read the variables, but I want to see the line by line script.
My goal is to write a tracking script to an X,Y coordinate. Someone wanted to do a similar thing using a GPS module about a year ago.
I see there is a camera coordinate X and Y in the variable list. I wanted to see how it was used in his script.
I can read where the robot is now ( X and Y value), and know where I want it to go (X and Y value). I need to borrow or write how to travel from and to.
Ron R
Hmmm, don't mean to be negative here but camera tracking isn't written in ARC script language.... it's written in C# (behind the scenes) as far as I know. Unless you understand C# I doubt it would be of any use to you...and GPS is only accurate within 10ft so that won't help you either indoors... Why don't you wait for David's Lidar/mapping pluggin?... It will give you (and everyone else) "SLAM" style indoor navigation... I mean that's what I am doing....
Hi Richard, Happy New Year.
Thanks for the information on the camera tracking. I thought I might be able to look at the script, but understand it is "behind the scenes". I believe the GPS concept was something someone was going to use outside. I wasn't thinking of GPS, just tracking to two coordinates.
I know you are also looking for indoor navigation, and I am sure David's idea will be "top drawer" once he completes it. I know it will meet our needs.
My desire at this time is a simple system, which will be better than the on board camera tracking or, auto positioning or mapping playback. I have an idea which requires scripting. Even with my limited ability I want to try this "Tracking", which isn't truly navigation. I had hoped there was something I could look at.
I will continue to play with this and post results and questions on the "Reading and Using servo Values In Tracking" thread.
I always respect your opinions and never take them in a negative way. I just, like you, enjoy the hobby of Robotics and want to try things and learn.
Ron R
I don't think providing the tracking algorithms would be very helpful as it's just a pile of math and equations.
What would you like to know? Maybe I can provide an answer for direction.
Hi Dj,
My end goal is to track to two preset coordinates, loaded from a verbal command ("go to the door").
The following is my idea: I read the loaded variables, then compare these coordinates to coordinates of two tracking cameras, looking at a target on my robot. These cameras are located 90 degrees apart in the area (two out side walls). Using Omni wheels mounted on two continuous servos, I plan on moving in the direction to match these coordinates. As the number get closer, I slow the continuous servos until the numbers match, then stop.
I started to write a concept script on paper using only one camera/servo and one continuous servo. I know your camera tracking lists an x and y coordinate and wanted to see how you wrote the script to track to them. This way I could see if I was on the right track. My idea is to do compares, then adjust the position of the robot until it matches.
I am a very new writer of scripts. The only exposure to programming was ladder logic and machine code many many years ago....LOL.. I will continue to play and post the script once it is written.
Any help or direction is appreciated. I really want to try this idea. I have future ideas to incorporate into it once it works.
Ron R
You cannot use a continuous rotation servo for tracking because it is unable to respond to position commands. It doesn't have a sense of positioning, it only knows to move a direction.
No, I am using the continuous servos to move only the robot. The camera is mounted on a regular servo, which is on a stationary location by an outside wall.. It is used to track the robot. For the initial test, I will have a long cable from the EZB in the Adventure Bot to the servo under the camera by a perimeter wall. As the Bot moves, the value sent to the camera servo to follow the target on the robot's back is my feedback. I will be using an Adventure Bot as the Target and a web cam connected to my computer as the feed back. I will load a coordinate and hopefully track to it.
I may have to make a video of the concept to eliminate some of the hardware confusion.
Ron R
Apologies Andy, i feel the question regarding how the vision tracking system identifies object positioning within ARC may be highly above your current programming capabilities based on this thread.
I do encourage learning - which is why we spent years developing and growing the LEARN section of this website. There is an activities course which will be very important to the education process. I recommend successfully completing the activities. Once you have accomplished the activities and have a grasp of logic programming, use the EXAMPLES folder in ARC to view EZ-Script examples.
This is because the question that you are asking about how object positioning is identified is quite complicated. There are many "steps" with complicated programming that identifies and detects objects. However, the answer to your specific question about how the detected object's position has been identified uses the aforge blobcounter library - which is as good or better than i could have written - which is why building off existing frameworks is important. Much like how you create robot projects in ARC...
This is because without ARC, you would need to understand this. And remember, this is only one module of 30 or so that relates to vision tracking in ARC. If this doesn't make sense to you, stick with ARC:). This code example is responsible for identifying the detected object position and assigning to ARC variables:
// AForge Image Processing Library
// AForge.NET framework
// https://www.aforgenet.com/framework/
// Copyright (c) AForge.NET, 2005-2012
// [email protected]
namespace AForge.Imaging
    using System;
    using System.Collections.Generic;
    using System.Drawing;
    using System.Drawing.Imaging;
    using AForge;
    /// <summary>
    /// Possible object orders.
    /// </summary>
    /// <remarks>The enumeration defines possible sorting orders of objects, found by blob
    /// counting classes.</remarks>
    public enum ObjectsOrder
        /// <summary>
        /// Unsorted order (as it is collected by algorithm).
        /// </summary>
        None,
        /// <summary>
        /// Objects are sorted by size in descending order (bigger objects go first).
        /// Size is calculated as <b>Width * Height</b>.
        /// </summary>
        Size,
        /// <summary>
        /// Objects are sorted by area in descending order (bigger objects go first).
        /// </summary>
        Area,
        /// <summary>
        /// Objects are sorted by Y coordinate, then by X coordinate in ascending order
        /// (smaller coordinates go first).
        /// </summary>
        YX,
        /// <summary>
        /// Objects are sorted by X coordinate, then by Y coordinate in ascending order
        /// </summary>
        XY
    /// <summary>
    /// Base class for different blob counting algorithms.
    /// </summary>
    /// <remarks><para>The class is abstract and serves as a base for different blob counting algorithms.
    /// Classes, which inherit from this base class, require to implement <see cref="BuildObjectsMap"/>
    /// method, which does actual building of object's label's map.</para>
    /// <para>For blobs' searcing usually all inherited classes accept binary images, which are actually
    /// grayscale thresholded images. But the exact supported format should be checked in particular class,
    /// inheriting from the base class. For blobs' extraction the class supports grayscale (8 bpp indexed)
    /// and color images (24 and 32 bpp).</para>
    /// <para>Sample usage:</para>
    /// <code>
    /// // create an instance of blob counter algorithm
    /// BlobCounterBase bc = new ...
    /// // set filtering options
    /// bc.FilterBlobs = true;
    /// bc.MinWidth  = 5;
    /// bc.MinHeight = 5;
    /// // process binary image
    /// bc.ProcessImage( image );
    /// Blob[] blobs = bc.GetObjects( image, false );
    /// // process blobs
    /// foreach ( Blob blob in blobs )
    ///     // blob.Rectangle - blob's rectangle
    ///     // blob.Image - blob's image
    /// </code>
    /// </remarks>
    public abstract class BlobCounterBase
        // found blobs
        List<Blob> blobs = new List<Blob>( );
        // objects' sort order
        private ObjectsOrder objectsOrder = ObjectsOrder.None;
        // filtering by size is required or not
        private bool filterBlobs = false;
        private IBlobsFilter filter = null;
        // coupled size filtering or not
        private bool coupledSizeFiltering = false;
        // blobs' minimal and maximal size
        private int minWidth    = 1;
        private int minHeight   = 1;
        private int maxWidth    = int.MaxValue;
        private int maxHeight   = int.MaxValue;
        /// <summary>
        /// Objects count.
        /// </summary>
        protected int objectsCount;
        /// <summary>
        /// Objects' labels.
        /// </summary>
        protected int[] objectLabels;
        /// <summary>
        /// Width of processed image.
        /// </summary>
        protected int imageWidth;
        /// <summary>
        /// Height of processed image.
        /// </summary>
        protected int imageHeight;
        /// <summary>
        /// Objects count.
        /// </summary>
        /// <remarks><para>Number of objects (blobs) found by <see cref="ProcessImage(Bitmap)"/> method.
        /// </para></remarks>
        public int ObjectsCount
            get { return objectsCount; }
        /// <summary>
        /// </summary>
        /// <remarks>The array of <b>width</b> * <b>height</b> size, which holds
        /// labels for all objects. Background is represented with <b>0</b> value,
        /// but objects are represented with labels starting from <b>1</b>.</remarks>
        public int[] ObjectLabels
            get { return objectLabels; }
        /// <summary>
        /// Objects sort order.
        /// </summary>
        /// <remarks><para>The property specifies objects' sort order, which are provided
        /// by <see cref="GetObjectsRectangles"/>, <see cref="GetObjectsInformation"/>, etc.
        public ObjectsOrder ObjectsOrder
            get { return objectsOrder; }
            set { objectsOrder = value; }
        /// <summary>
        /// Specifies if blobs should be filtered.
        /// </summary>
        /// <remarks><para>If the property is equal to <b>false</b>, then there is no any additional
        /// post processing after image was processed. If the property is set to <b>true</b>, then
        /// blobs filtering is done right after image processing routine. If <see cref="BlobsFilter"/>
        /// is set, then custom blobs' filtering is done, which is implemented by user. Otherwise
        /// blobs are filtered according to dimensions specified in <see cref="MinWidth"/>,
        /// <see cref="MinHeight"/>, <see cref="MaxWidth"/> and <see cref="MaxHeight"/> properties.</para>
        /// <para>Default value is set to <see langword="false"/>.</para></remarks>
        public bool FilterBlobs
            get { return filterBlobs; }
            set { filterBlobs = value; }
        /// <summary>
        /// Specifies if size filetering should be coupled or not.
        /// </summary>
        /// <remarks><para>In uncoupled filtering mode, objects are filtered out in the case if
        /// their width is smaller than <see cref="MinWidth"/> <b>or</b> height is smaller than
        /// <see cref="MinHeight"/>. But in coupled filtering mode, objects are filtered out in
        /// the case if their width is smaller than <see cref="MinWidth"/> <b>and</b> height is
        /// smaller than <see cref="MinHeight"/>. In both modes the idea with filtering by objects'
        /// maximum size is the same as filtering by objects' minimum size.</para>
        /// <para>Default value is set to <see langword="false"/>, what means uncoupled filtering by size.</para>
        /// </remarks>
        public bool CoupledSizeFiltering
            get { return coupledSizeFiltering; }
            set { coupledSizeFiltering = value; }
        /// <summary>
        /// Minimum allowed width of blob.
        /// </summary>
        /// <remarks><para>The property specifies minimum object's width acceptable by blob counting
        /// routine and has power only when <see cref="FilterBlobs"/> property is set to
        /// <see langword="true"/> and <see cref="BlobsFilter">custom blobs' filter</see> is
        /// set to <see langword="null"/>.</para>
        /// <para>See documentation to <see cref="CoupledSizeFiltering"/> for additional information.</para>
        /// </remarks>
        public int MinWidth
            get { return minWidth; }
            set { minWidth = value; }
        /// <summary>
        /// Minimum allowed height of blob.
        /// </summary>
        /// <remarks><para>The property specifies minimum object's height acceptable by blob counting
        /// </remarks>
        public int MinHeight
            get { return minHeight; }
            set { minHeight = value; }
        /// <summary>
        /// Maximum allowed width of blob.
        /// </summary>
        /// <remarks><para>The property specifies maximum object's width acceptable by blob counting
        /// </remarks>
        public int MaxWidth
            get { return maxWidth; }
            set { maxWidth = value; }
        /// <summary>
        /// Maximum allowed height of blob.
        /// </summary>
        /// <remarks><para>The property specifies maximum object's height acceptable by blob counting
        /// </remarks>
        public int MaxHeight
            get { return maxHeight; }
            set { maxHeight = value; }
        /// <summary>
        /// Custom blobs' filter to use.
        /// </summary>
        /// <remarks><para>The property specifies custom blobs' filtering routine to use. It has
        /// effect only in the case if <see cref="FilterBlobs"/> property is set to <see langword="true"/>.</para>
        /// <para><note>When custom blobs' filtering routine is set, it has priority over default filtering done
        /// with <see cref="MinWidth"/>, <see cref="MinHeight"/>, <see cref="MaxWidth"/> and <see cref="MaxHeight"/>.</note></para>
        /// </remarks>
        public IBlobsFilter BlobsFilter
            get { return filter; }
            set { filter = value; }
        /// <summary>
        /// Initializes a new instance of the <see cref="BlobCounterBase"/> class.
        /// </summary>
        /// <remarks>Creates new instance of the <see cref="BlobCounterBase"/> class with
        /// an empty objects map. Before using methods, which provide information about blobs
        /// or extract them, the <see cref="ProcessImage(Bitmap)"/>,
        /// <see cref="ProcessImage(BitmapData)"/> or <see cref="ProcessImage(UnmanagedImage)"/>
        /// method should be called to collect objects map.</remarks>
        public BlobCounterBase( ) { }
        /// <summary>
        /// </summary>
        /// <param name="image">Binary image to look for objects in.</param>
        /// initialized objects map built by calling <see cref="ProcessImage(Bitmap)"/> method.</remarks>
        public BlobCounterBase( Bitmap image )
        /// <summary>
        /// </summary>
        /// <param name="imageData">Binary image data to look for objects in.</param>
        /// initialized objects map built by calling <see cref="ProcessImage(BitmapData)"/> method.</remarks>
        public BlobCounterBase( BitmapData imageData )
            ProcessImage( imageData );
        /// <summary>
        /// </summary>
        /// <param name="image">Unmanaged binary image to look for objects in.</param>
        /// initialized objects map built by calling <see cref="ProcessImage(UnmanagedImage)"/> method.</remarks>
        public BlobCounterBase( UnmanagedImage image )
        /// <summary>
        /// Build objects map.
        /// </summary>
        /// <param name="image">Source binary image.</param>
        /// <remarks><para>Processes the image and builds objects map, which is used later to extracts blobs.</para></remarks>
        /// <exception cref="UnsupportedImageFormatException">Unsupported pixel format of the source image.</exception>
        public void ProcessImage( Bitmap image )
            // lock source bitmap data
            BitmapData imageData = image.LockBits(
                new Rectangle( 0, 0, image.Width, image.Height ),
                ImageLockMode.ReadOnly, image.PixelFormat );
            try
                // process image
            finally
                // unlock source image
                image.UnlockBits( imageData );
        /// <summary>
        /// </summary>
        /// <param name="imageData">Source binary image data.</param>
        public void ProcessImage( BitmapData imageData )
            // do actual objects map building
            ProcessImage( new UnmanagedImage( imageData ) );
        /// <summary>
        /// Build object map from raw image data.
        /// </summary>
        /// <param name="image">Source unmanaged binary image data.</param>
        /// <exception cref="InvalidImagePropertiesException">Thrown by some inherited classes if some image property other
        /// than the pixel format is not supported. See that class's documentation or the exception message for details.</exception>
        public void ProcessImage( UnmanagedImage image )
            imageWidth  = image.Width;
            imageHeight = image.Height;
            BuildObjectsMap( image );
            // collect information about blobs
            CollectObjectsInfo( image );
            // filter blobs by size if required
            if ( filterBlobs )
                // labels remapping array
                int[] labelsMap = new int[objectsCount + 1];
                for ( int i = 1; i <= objectsCount; i++ )
                    labelsMap[i] = i;
                // check dimension of all objects and filter them
                int objectsToRemove = 0;
                if ( filter == null )
                    for ( int i = objectsCount - 1; i >= 0; i-- )
                        int blobWidth  = blobs[i].Rectangle.Width;
                        int blobHeight = blobs[i].Rectangle.Height;
                        if ( coupledSizeFiltering == false )
                            // uncoupled filtering
                            if (
                                ( blobWidth < minWidth ) || ( blobHeight < minHeight ) ||
                                ( blobWidth > maxWidth ) || ( blobHeight > maxHeight ) )
                                labelsMap[i + 1] = 0;
                                objectsToRemove++;
                                blobs.RemoveAt( i );
                        else
                            // coupled filtering
                            if (
                                ( ( blobWidth < minWidth ) && ( blobHeight < minHeight ) ) ||
                                ( ( blobWidth > maxWidth ) && ( blobHeight > maxHeight ) ) )
                                objectsToRemove++;
                else
                        if ( !filter.Check( blobs[i] ) )
                            objectsToRemove++;
                // update labels remapping array
                int label = 0;
                    if ( labelsMap[i] != 0 )
                        label++;
                        // update remapping array
                        labelsMap[i] = label;
                // repair object labels
                for ( int i = 0, n = objectLabels.Length; i < n; i++ )
                    objectLabels[i] = labelsMap[objectLabels[i]];
                objectsCount -= objectsToRemove;
                // repair IDs
                for ( int i = 0, n = blobs.Count; i < n; i++ )
                    blobs[i].ID = i + 1;
            // do we need to sort the list?
            if ( objectsOrder != ObjectsOrder.None )
                blobs.Sort( new BlobsSorter( objectsOrder ) );
        /// <summary>
        /// Get objects' rectangles.
        /// </summary>
        /// <returns>Returns array of objects' rectangles.</returns>
        /// <remarks>The method returns array of objects rectangles. Before calling the
        /// method, the <see cref="ProcessImage(Bitmap)"/>, <see cref="ProcessImage(BitmapData)"/>
        /// or <see cref="ProcessImage(UnmanagedImage)"/> method should be called, which will
        /// build objects map.</remarks>
        /// <exception cref="ApplicationException">No image was processed before, so objects' rectangles
        /// can not be collected.</exception>
        public Rectangle[] GetObjectsRectangles( )
            // check if objects map was collected
            if ( objectLabels == null )
                throw new ApplicationException( "Image should be processed before to collect objects map." );
            Rectangle[] rects = new Rectangle[objectsCount];
            for ( int i = 0; i < objectsCount; i++ )
                rects[i] = blobs[i].Rectangle;
            return rects;
        /// <summary>
        /// Get objects' information.
        /// </summary>
        /// <returns>Returns array of partially initialized blobs (without <see cref="Blob.Image"/> property initialized).</returns>
        /// <remarks><para>By the amount of provided information, the method is between <see cref="GetObjectsRectangles"/> and
        /// <see cref="GetObjects( UnmanagedImage, bool )"/> methods. The method provides array of blobs without initialized their image.
        /// Blob's image may be extracted later using <see cref="ExtractBlobsImage( Bitmap, Blob, bool )"/>
        /// or <see cref="ExtractBlobsImage( UnmanagedImage, Blob, bool )"/> method.
        /// <example>
        /// <code>
        /// // create blob counter and process image
        /// BlobCounter bc = new BlobCounter( sourceImage );
        /// // specify sort order
        /// bc.ObjectsOrder = ObjectsOrder.Size;
        /// // get objects' information (blobs without image)
        /// Blob[] blobs = bc.GetObjectInformation( );
        ///     // check blob's properties
        ///     if ( blob.Rectangle.Width > 50 )
        ///         // the blob looks interesting, let's extract it
        ///         bc.ExtractBlobsImage( sourceImage, blob );
        /// </code>
        /// </example>
        /// <exception cref="ApplicationException">No image was processed before, so objects' information
        public Blob[] GetObjectsInformation( )
            Blob[] blobsToReturn = new Blob[objectsCount];
            // create each blob
            for ( int k = 0; k < objectsCount; k++ )
                blobsToReturn[k] = new Blob( blobs[k] );
            return blobsToReturn;
        /// <summary>
        /// Get blobs.
        /// </summary>
        /// <param name="image">Source image to extract objects from.</param>
        /// <returns>Returns array of blobs.</returns>
        /// <param name="extractInOriginalSize">Specifies size of blobs' image to extract.
        /// If set to <see langword="true"/> each blobs' image will have the same size as
        /// the specified image. If set to <see langword="false"/> each blobs' image will
        /// have the size of its blob.</param>
        /// <remarks><para>The method returns array of blobs. Before calling the
        /// or <see cref="ProcessImage(UnmanagedImage)"/> method should be called, which will build
        /// objects map.</para>
        /// <para>The method supports 24/32 bpp color and 8 bpp indexed grayscale images.</para>
        /// </remarks>
        /// <exception cref="UnsupportedImageFormatException">Unsupported pixel format of the provided image.</exception>
        public Blob[] GetObjects( Bitmap image, bool extractInOriginalSize )
            Blob[] blobs = null;
            try
                // process image
                blobs = GetObjects( new UnmanagedImage( imageData ), extractInOriginalSize );
            finally
                // unlock source images
            return blobs;
        /// <summary>
        /// Get blobs.
        /// </summary>
        /// <param name="image">Source unmanaged image to extract objects from.</param>
        /// </remarks>
        public Blob[] GetObjects( UnmanagedImage image, bool extractInOriginalSize )
            if (
                ( image.PixelFormat != PixelFormat.Format24bppRgb ) &&
                ( image.PixelFormat != PixelFormat.Format8bppIndexed ) &&
                ( image.PixelFormat != PixelFormat.Format32bppRgb ) &&
                ( image.PixelFormat != PixelFormat.Format32bppArgb ) &&
                ( image.PixelFormat != PixelFormat.Format32bppPArgb )
                throw new UnsupportedImageFormatException( "Unsupported pixel format of the provided image." );
            // image size
            int width  = image.Width;
            int height = image.Height;
            int srcStride = image.Stride;
            int pixelSize = Bitmap.GetPixelFormatSize( image.PixelFormat ) / 8;
            Blob[] objects = new Blob[objectsCount];
            // create each image
                int objectWidth  = blobs[k].Rectangle.Width;
                int objectHeight = blobs[k].Rectangle.Height;
                int blobImageWidth  = ( extractInOriginalSize ) ? width : objectWidth;
                int blobImageHeight = ( extractInOriginalSize ) ? height : objectHeight;
                int xmin = blobs[k].Rectangle.X;
                int xmax = xmin + objectWidth - 1;
                int ymin = blobs[k].Rectangle.Y;
                int ymax = ymin + objectHeight - 1;
                int label = blobs[k].ID;
                // create new image
                UnmanagedImage dstImage = UnmanagedImage.Create( blobImageWidth, blobImageHeight, image.PixelFormat );
                // copy image
                unsafe
                    byte* src = (byte*) image.ImageData.ToPointer( ) + ymin * srcStride + xmin * pixelSize;
                    byte* dst = (byte*) dstImage.ImageData.ToPointer( );
                    int p = ymin * width + xmin;
                    if ( extractInOriginalSize )
                        // allign destination pointer also
                        dst += ymin * dstImage.Stride + xmin * pixelSize;
                    int srcOffset = srcStride - objectWidth * pixelSize;
                    int dstOffset = dstImage.Stride - objectWidth * pixelSize;
                    int labelsOffset = width - objectWidth;
                    // for each line
                    for ( int y = ymin; y <= ymax; y++ )
                        // copy each pixel
                        for ( int x = xmin; x <= xmax; x++, p++, dst += pixelSize, src += pixelSize )
                            if ( objectLabels[p] == label )
                                // copy pixel
                                *dst = *src;
                                if ( pixelSize > 1 )
                                    dst[1] = src[1];
                                    dst[2] = src[2];
                                    if ( pixelSize > 3 )
                                        dst[3] = src[3];
                        src += srcOffset;
                        dst += dstOffset;
                        p += labelsOffset;
                objects[k] = new Blob( blobs[k] );
                objects[k].Image = dstImage;
                objects[k].OriginalSize = extractInOriginalSize;
            return objects;
        /// <summary>
        /// Extract blob's image.
        /// </summary>
        /// <param name="image">Source image to extract blob's image from.</param>
        /// <param name="blob">Blob which is required to be extracted.</param>
        /// <remarks><para>The method is used to extract image of partially initialized blob, which
        /// was provided by <see cref="GetObjectsInformation"/> method. Before calling the
        /// </remarks>
        /// <exception cref="ApplicationException">No image was processed before, so blob
        /// can not be extracted.</exception>
        public void ExtractBlobsImage( Bitmap image, Blob blob, bool extractInOriginalSize )
            try
                // process image
                ExtractBlobsImage( new UnmanagedImage( imageData ), blob, extractInOriginalSize );
            finally
        /// <summary>
        /// </summary>
        /// <param name="image">Source unmanaged image to extract blob's image from.</param>
        /// </remarks>
        public void ExtractBlobsImage( UnmanagedImage image, Blob blob, bool extractInOriginalSize )
            if (
            // image size
            int objectWidth  = blob.Rectangle.Width;
            int objectHeight = blob.Rectangle.Height;
            int xmin = blob.Rectangle.Left;
            int ymin = blob.Rectangle.Top;
            int label = blob.ID;
            // create new image
            blob.Image = UnmanagedImage.Create( blobImageWidth, blobImageHeight, image.PixelFormat );
            blob.OriginalSize = extractInOriginalSize;
            // copy image
            unsafe
                byte* dst = (byte*) blob.Image.ImageData.ToPointer( );
                    dst += ymin * blob.Image.Stride + xmin * pixelSize;
                int dstOffset = blob.Image.Stride - objectWidth * pixelSize;
                // for each line
                    // copy each pixel
                            // copy pixel
                            *dst = *src;
                                dst[1] = src[1];
                                dst[2] = src[2];
                                    dst[3] = src[3];
                    src += srcOffset;
                    dst += dstOffset;
                    p += labelsOffset;
        /// <summary>
        /// Get list of points on the left and right edges of the blob.
        /// </summary>
        /// <param name="blob">Blob to collect edge points for.</param>
        /// <param name="leftEdge">List of points on the left edge of the blob.</param>
        /// <param name="rightEdge">List of points on the right edge of the blob.</param>
        /// <remarks><para>The method scans each line of the blob and finds the most left and the
        /// most right points for it adding them to appropriate lists. The method may be very
        /// useful in conjunction with different routines from <see cref="AForge.Math.Geometry"/>,
        /// which allow finding convex hull or quadrilateral's corners.</para>
        /// <para><note>Both lists of points are sorted by Y coordinate - points with smaller Y
        /// value go first.</note></para>
        /// </remarks>
        public void GetBlobsLeftAndRightEdges( Blob blob, out List<IntPoint> leftEdge, out List<IntPoint> rightEdge )
            leftEdge  = new List<IntPoint>( );
            rightEdge = new List<IntPoint>( );
            int xmax = xmin + blob.Rectangle.Width - 1;
            int ymax = ymin + blob.Rectangle.Height - 1;
            // for each line
                // scan from left to right
                int p = y * imageWidth + xmin;
                for ( int x = xmin; x <= xmax; x++, p++ )
                        leftEdge.Add( new IntPoint( x, y ) );
                        break;
                // scan from right to left
                p = y * imageWidth + xmax;
                for ( int x = xmax; x >= xmin; x--, p-- )
                        rightEdge.Add( new IntPoint( x, y ) );
                        break;
        /// <summary>
        /// Get list of points on the top and bottom edges of the blob.
        /// </summary>
        /// <param name="topEdge">List of points on the top edge of the blob.</param>
        /// <param name="bottomEdge">List of points on the bottom edge of the blob.</param>
        /// <remarks><para>The method scans each column of the blob and finds the most top and the
        /// most bottom points for it adding them to appropriate lists. The method may be very
        /// <para><note>Both lists of points are sorted by X coordinate - points with smaller X
        /// </remarks>
        public void GetBlobsTopAndBottomEdges( Blob blob, out List<IntPoint> topEdge, out List<IntPoint> bottomEdge )
            topEdge    = new List<IntPoint>( );
            bottomEdge = new List<IntPoint>( );
            // for each column
            for ( int x = xmin; x <= xmax; x++ )
                // scan from top to bottom
                int p = ymin * imageWidth + x;
                for ( int y = ymin; y <= ymax; y++, p += imageWidth )
                        topEdge.Add( new IntPoint( x, y ) );
                        break;
                // scan from bottom to top
                p = ymax * imageWidth + x;
                for ( int y = ymax; y >= ymin; y--, p -= imageWidth )
                        bottomEdge.Add( new IntPoint( x, y ) );
                        break;
        /// <summary>
        /// Get list of object's edge points.
        /// </summary>
        /// <returns>Returns unsorted list of blob's edge points.</returns>
        /// <remarks><para>The method scans each row and column of the blob and finds the
        /// most top/bottom/left/right points. The method returns similar result as if results of
        /// both <see cref="GetBlobsLeftAndRightEdges"/> and <see cref="GetBlobsTopAndBottomEdges"/>
        /// methods were combined, but each edge point occurs only once in the list.</para>
        /// <para><note>Edge points in the returned list are not ordered. This makes the list unusable
        /// for visualization with methods, which draw polygon or poly-line. But the returned list
        /// can be used with such algorithms, like convex hull search, shape analyzer, etc.</note></para>
        /// </remarks>
        public List<IntPoint> GetBlobsEdgePoints( Blob blob )
            List<IntPoint> edgePoints = new List<IntPoint>( );
            // array of already processed points on left/right edges
            // (index in these arrays represent Y coordinate, but value - X coordinate)
            int[] leftProcessedPoints  = new int[blob.Rectangle.Height];
            int[] rightProcessedPoints = new int[blob.Rectangle.Height];
            // for each line
                        edgePoints.Add( new IntPoint( x, y ) );
                        leftProcessedPoints[y - ymin] = x;
                        break;
                        // avoid adding the point we already have
                        if ( leftProcessedPoints[y - ymin] != x )
                        rightProcessedPoints[y - ymin] = x;
                        break;
            // for each column
                for ( int y = ymin, y0 = 0; y <= ymax; y++, y0++, p += imageWidth )
                        if ( ( leftProcessedPoints[y0] != x ) &&
                             ( rightProcessedPoints[y0] != x ) )
                        break;
                for ( int y = ymax, y0 = ymax - ymin; y >= ymin; y--, y0--, p -= imageWidth )
                        break;
            return edgePoints;
        /// <summary>
        /// Actual objects map building.
        /// </summary>
        /// <param name="image">Unmanaged image to process.</param>
        /// <remarks><note>By the time this method is called bitmap's pixel format is not
        /// yet checked, so this should be done by the class inheriting from the base class.
        /// <see cref="imageWidth"/> and <see cref="imageHeight"/> members are initialized
        /// before the method is called, so these members may be used safely.</note></remarks>
        protected abstract void BuildObjectsMap( UnmanagedImage image );
        #region Private Methods - Collecting objects' rectangles
        // Collect objects' rectangles
        private unsafe void CollectObjectsInfo( UnmanagedImage image )
            int i = 0, label;
            // create object coordinates arrays
            int[] x1 = new int[objectsCount + 1];
            int[] y1 = new int[objectsCount + 1];
            int[] x2 = new int[objectsCount + 1];
            int[] y2 = new int[objectsCount + 1];
            int[] area = new int[objectsCount + 1];
            long[] xc = new long[objectsCount + 1];
            long[] yc = new long[objectsCount + 1];
            long[] meanR = new long[objectsCount + 1];
            long[] meanG = new long[objectsCount + 1];
            long[] meanB = new long[objectsCount + 1];
            long[] stdDevR = new long[objectsCount + 1];
            long[] stdDevG = new long[objectsCount + 1];
            long[] stdDevB = new long[objectsCount + 1];
            for ( int j = 1; j <= objectsCount; j++ )
                x1[j] = imageWidth;
                y1[j] = imageHeight;
            byte* src = (byte*) image.ImageData.ToPointer( );
            if ( image.PixelFormat == PixelFormat.Format8bppIndexed )
                int offset = image.Stride - imageWidth;
                byte g; // pixel's grey value
                // walk through labels array
                for ( int y = 0; y < imageHeight; y++ )
                    for ( int x = 0; x < imageWidth; x++, i++, src++ )
                        // get current label
                        label = objectLabels[i];
                        // skip unlabeled pixels
                        if ( label == 0 )
                            continue;
                        // check and update all coordinates
                        if ( x < x1[label] )
                            x1[label] = x;
                        if ( x > x2[label] )
                            x2[label] = x;
                        if ( y < y1[label] )
                            y1[label] = y;
                        if ( y > y2[label] )
                            y2[label] = y;
                        area[label]++;
                        xc[label] += x;
                        yc[label] += y;
                        g = *src;
                        meanG[label] += g;
                        stdDevG[label] += g * g;
                    src += offset;
                    meanR[j] = meanB[j] = meanG[j];
                    stdDevR[j] = stdDevB[j] = stdDevG[j];
            else
                // color images
                int offset = image.Stride - imageWidth * pixelSize;
                byte r, g, b; // RGB value
                    for ( int x = 0; x < imageWidth; x++, i++, src += pixelSize )
                        if ( label == 0 )
                            continue;
                            x1[label] = x;
                            x2[label] = x;
                            y1[label] = y;
                            y2[label] = y;
                        area[label]++;
                        xc[label] += x;
                        yc[label] += y;
                        r = src[RGB.R];
                        g = src[RGB.G];
                        b = src[RGB.B];
                        meanR[label] += r;
                        meanG[label] += g;
                        meanB[label] += b;
                        stdDevR[label] += r * r;
                        stdDevB[label] += b * b;
                    src += offset;
            // create blobs
            blobs.Clear( );
                int blobArea = area[j];
                Blob blob = new Blob( j, new Rectangle( x1[j], y1[j], x2[j] - x1[j] + 1, y2[j] - y1[j] + 1 ) );
                blob.Area = blobArea;
                blob.Fullness = (double) blobArea / ( ( x2[j] - x1[j] + 1 ) * ( y2[j] - y1[j] + 1 ) );
                blob.CenterOfGravity = new AForge.Point( (float) xc[j] / blobArea, (float) yc[j] / blobArea );
                blob.ColorMean = Color.FromArgb( (byte) ( meanR[j] / blobArea ), (byte) ( meanG[j] / blobArea ), (byte) ( meanB[j] / blobArea ) );
                blob.ColorStdDev = Color.FromArgb(
                    (byte) ( Math.Sqrt( stdDevR[j] / blobArea - blob.ColorMean.R * blob.ColorMean.R ) ),
                    (byte) ( Math.Sqrt( stdDevG[j] / blobArea - blob.ColorMean.G * blob.ColorMean.G ) ),
                    (byte) ( Math.Sqrt( stdDevB[j] / blobArea - blob.ColorMean.B * blob.ColorMean.B ) ) );
                blobs.Add( blob );
        // Rectangles' and blobs' sorter
        private class BlobsSorter : System.Collections.Generic.IComparer<Blob>
            private ObjectsOrder order;
            public BlobsSorter( ObjectsOrder order )
                this.order = order;
            public int Compare( Blob a, Blob b )
                Rectangle aRect = a.Rectangle;
                Rectangle bRect = b.Rectangle;
                switch ( order )
                    case ObjectsOrder.Size: // sort by size
                        // the order is changed to descending
                        return ( bRect.Width * bRect.Height - aRect.Width * aRect.Height );
                    case ObjectsOrder.Area: // sort by area
                        return b.Area - a.Area;
                    case ObjectsOrder.YX:   // YX order
                        return ( ( aRect.Y * 100000 + aRect.X ) - ( bRect.Y * 100000 + bRect.X ) );
                    case ObjectsOrder.XY:   // XY order
                        return ( ( aRect.X * 100000 + aRect.Y ) - ( bRect.X * 100000 + bRect.Y ) );
                return 0;
        #endregion
Thanks Dj,
I had assumed the "camera tracking" used a "script" developed thru ARC, and additional code running in the background. I just looked at the surface results and never put thought into what was really going on.
Thanks for posting the information, but as you can tell, my background does not give me the ability to use it.
I have re-posted my thread on tracking using servo position information, and will continue to go forward with that scripting.
Thanks again,
Ron R
