Aimlbot icon Aimlbot — Localized AIML chatbot with editable AIML files, ez-script support, session memory and ControlCommand API; integrates with speech and robot skills. Try it →
I forgot to mention that you can check for the object with $CameraIsTracking (Which is a 0/1 or true/false)
So you can do this...
if ($CameraIsTracking = 1)
  SayEZB("I see an object")
else
  SayEZB("There is no object ")
endif
-OR-
if ($CameraIsTracking = true)
else
endif
-OR-
if ($CameraIsTracking)
else
endif
You can see what the Camera Variables are by...
  1. Pressing the Configuration Gear on the CAmera Control
  2. Selecting SCRIPTS tab from the camera control configuration window
  3. Selecting VARIABLES tab
It will look like this...
Thanks , that is a way more elegant way to handle that.
I program in many languages and am still learning the syntax of EZScript.
I know if I started posting code you guys would set me straight.
@Luis Did you post your project on the cloud? I cannot find it. I would like to learn from what you have done.
Thanks. Wayne
Sorry @WayneA I have not done that yet. I will get to that later today. I need to clean up some personal stuff from the project first. If you are subscribed to this post . I will post here when I have it up , so you can get notified.
@Luis Ok. Thank You very much!
Hello all and @WayneA
Sorry about the delay .. I have posted the project with the vision interaction to the cloud.
file name is JD vission
Let me know if you can find it.
#15
@Luis I found your code from the cloud. I think it is very good for me to learn from. On a darkside, my poor computer cannot keep up with the vision and microphone listening. I seriously need to update my computer system.
Thank You Very Much.
