Irobot Roomba Movement Panel icon Irobot Roomba Movement Panel — Control Roomba/Create via ARC: drive, stream sensors, read encoders, configure COM/HW UART, and send pose to NMS for mapping/navigation. Try it →
I get the same errors.
I once got the Omnibot examles in the SDK to run many releases ago but have had no luck for awhile now.
However the ARC platform is becoming a whole language of its own and requires some thinking about as it offers so much versatilaty
I can't imagine what the difference between our systems are. Have you tried setting the project to use .Net 3.5?
Yep tried that
confused
Yes I have set it to use 3.5 and then when it ask me to save the project it just hangs again.
EDIT: Wow, 39 secs after your post !
I haven't had a chance to try the last few builds - been focusing mostly on hardware. I'll update and fire it up tomorrow to see what happens for me...
Just downloaded and configured the latest SDK. Thus far I haven't experienced any errors loading the projects...
This is the process I use to get the SDK running on my systems:
(1) Add the following references to all projects: EZ-B.dll DirectX.dll DirectX.DirectInput.dll
(2) Select Clean Solution from the Build menu
(3) Select Rebuild Solution from the Build menu
Also, I have a fairly large number of development platforms, frameworks and SDKs installed on my systems for work-related projects and everything was working prior to adding the EZ-B goodies. I'm wondering if something is missing from the systems experiencing errors?
Note: I add the DirectX references to get rid of the unmanaged code debug warnings. SlimDX please? ;)
#15
I considered slimdx, but the performance is limited due to the abstraction layer for interop calls. I also would have to take a peak at their licensing for distribution.
#16
Hi im new to Visual C#, and this EZ-B platform. Im stuck in trying to run any of the sample code. not sure what to look for?
I have visual studio C# 2010, on win7. Using "Test - Servo"
  1. Ez-B board is powered on. ARC is closed.
  2. double click "Test - Servo.csproj" , the program converts it to the VS C# 2010 format.
  3. I've add references to EZ-B.dll, DirectX.dll, DirectX.DirectInput.dll, from the projects/Addreferences/browse area. 4)clicked "build>Build solution", no errors, no warnings.
now what do i do to run this code?
I double-clicked /C#/Test - Servo/bin/Release/Test - Servo.vshost.exe and nothing happened. am i suppose to have ARC running in the background? i looked around "Form1.cs" "form1.Designer.cs" "program.cs" and i did not modify anything.
