Lidar-Lite Laser Module icon Lidar-Lite Laser Module — Laser Lidar-Lite ARC control reads distance, velocity and signal strength (0-40m+) via EZ-B v4 i2c, setting EZ-Script vars for robotics Try it →
Vr Options?
Does anyone know if the SDK of the Oculus Rift package would work with EZB if there was a plug in developed for it? It doesn't really need to be something as big and bulky as that. Very unfortunate that Vuzix is no longer offering support with EZB. That would work great.
Like the Vuzix, I'd like to pull from the IMU data to move servos and transfer the camera feed from the EZ camera to the goggles over two complete separate computers in different places.
Any ideas or suggestions on how to POC this, would be grateful.
@fxrtst, So far no problem. I did most of the changes (code) remotely, looks good via remote camera & JD with a power supply.
@Mickey666Maus, Can you drop me an email ? i would like to ask some questions regarding existent code files.
#226
@PTP, that's great!
PS: No sound
Twitter
#229
Hi PTP VERY COOL. I Just installed unity and paid my $20 for BIO IK, JD_rigged_V4 up and running. Could you share EZ_B script please. Thanks
#231
Great job as always. Hat off to you good sir. FYI the way I rigged JD if you select the objects on left pane called right arm goal or left arm goal and move those around on the main window JD will move to follow.
#232
I’m sure I will have a thousand questions for you.
