ROS2 Connector icon ROS2 Connector — Bridge ARC to ROS2 via rosbridge: publish/subscribe topics for cameras, servos, ports, NMS, variables, scripts, and movement. Try it →
Vr Options?
Does anyone know if the SDK of the Oculus Rift package would work with EZB if there was a plug in developed for it? It doesn't really need to be something as big and bulky as that. Very unfortunate that Vuzix is no longer offering support with EZB. That would work great.
Like the Vuzix, I'd like to pull from the IMU data to move servos and transfer the camera feed from the EZ camera to the goggles over two complete separate computers in different places.
Any ideas or suggestions on how to POC this, would be grateful.
#41
@fxrtst I will look at it...looks promising, I am just downloading Unity now!
#42
Its quite different than we are used too. Its obvious a gaming engine, but there are parts of it that are familiar to 3d animation. The great thing is there is alot to be found on the internet via youtube etc, to help fill in the blank spots.
Also I replaced the Bio IK Video on post #39 with another one that shows VR use and manipulation at around the 4:00 minute mark.
#43
BTW I was able to get a simple scene from Lightwave to Unity. It had a Unity export plug in. I'm sure they have one for Max.
#44
Also found a great autorigging and bones FK IK system in the asset store, super easy to use. You can rig anything not just bipeds. So you could create any robot size or shape bring it in and rig it for auto or manual IK rigging. Very very simple to use. Called Puppet 3D.
#45
Yes, I could export my model with all the hierarchic dependencies into Unity... But its a bit tricky to get used too, but I agree on that it might be very much worth exploring!
I will check what you found! It all looks very good! The guy who invented the plugin lives nearby my hometown...funny!:D
#46
Yes it is definitely a gaming engine and not so much a 3d package. But once you add a few plug ins it works great. I will continue to test.
#47
Great, let me know how far you are getting...I am up to explore more! Just trying to send some values the ARCs Custom Server, but will have to call it a day soon! sleep
#48
So I guess it should work, you can send values out from Unity to ARC, this one for example connects the EZ-B in ARC on startup. The same way you could control servos...
using UnityEngine;
using System.Collections;
using UnityEngine.Networking;
public class MyScript : MonoBehaviour
    void Start()
        StartCoroutine(GetText());
    IEnumerator GetText()
        UnityWebRequest www = UnityWebRequest.Get("https://192.168.178.20/Exec?password=admin&script=ControlCommand(%22Connection%22,%20Connect0)";);
        yield return www.SendWebRequest();
        if (www.isNetworkError || www.isHttpError)
            Debug.Log(www.error);
        else
            // Show results as text
            Debug.Log(www.downloadHandler.text);
            // Or retrieve results as binary data
            byte[] results = www.downloadHandler.data;
