Openai Dall-E Image icon Openai Dall-E Image — Generate or edit images with OpenAI GPT Image from text or camera frames, with save and programmatic control commands. Try it →
New Zealand
Hi Team,
I may have identified a small bug with the WaitForSpeech command.
The command works fine when coding inside a script manager console but fails to work outside the editing environment.
I have also tried this inside a stand alone script window
Both methods hang with a partially drawn dialogue box with "Waiting for Speech..." visible. It eventually switches to "Not Responding" which of course forces me to close ARC.
I am using Win10 and the latest version of ARC.
I am unable to reproduce this behavior. Can you provide an example project? Use the attach file button when responding and attach the project file.
New Zealand
I hate to admit it but the problem is in my code DJ.... The function works perfectly in a fresh script outside my code
I have had this script working since 2007 so I am not surprised that a glitch has finally crept in.
Sounds like it is time to re-code.
We've all been there:)
