Auto Position (Gait) icon Auto Position (Gait) — Create servo frames and actions to animate gaits and gestures with automatic motion planning, software ramping, movement panel, import/export Try it →
Resolved Resolved by ptp!
Waiting for Audio from Soundboard (PC) to Finish
Waiting For Audio From Soundboard (PC) To Finish
Is there a way to wait for the end of an audio file from the Soundboard (PC) control? The following code does not wait but instead plays the file and says "done" simultaneously:
ControlCommand("Soundboard (PC)", Track_0)
WaitFor($EZBPlayingAudio = 0)
Say("done")
From my understanding, $EZBPlayingAudio is only applicable to sound coming from the EZB. As such, the following code works because it outputs from the EZB rather than the PC:
ControlCommand("Soundboard (EZB)", Track_0)
Say("done")
Is there an equivalent $EZBPlayingAudio variable for the Soundboard (PC) control?
JD Humanoid by EZ-Robot
Soundboard (PC) by Synthiam
Play and manage MP3/WAV sound effects from a PC soundboard, load tracks, trigger or script playback (one file at a time), export and automate.
There isn't a status variable for the soundboard PC at this time. I'll add it to the future todo list:)
Oh wow ptp that’s great
The AudioToolbox plugin looks promising. I managed to import the voices using scripts but I couldn't configure the default devices. When I try to open the plugin I get this error:
@Vincent.J I can't find that method (PopulateComboBoxes) in my code, did you upgrade to the last version #6 ? if you add the plugin to an empty project is your screen similar to this:
Note 1: warning messages due no mic / speaker devices.
@ptp the latest version I see is 5:
and with an empty project it looks like this:
@vincent.j: I uploaded the new version (#6).
@ptp It works, thanks!
