Servo Speed icon Servo Speed — Adjust servo/PWM speed (0-20) between two positions to quickly experiment and tune motion; select board/port; settings aren't saved. Try it →
U-command wall-e costs too much for me so i was thinking of trying the interaction Wall-e instead. Has anyone done this yet? if so can i hear you experiences? Should it work the same as "The Real Wall-e", meaning could it fit everything the same as "the real wall-e"?(servos, ez-b,ect.)
Thanks.
Size of the interaction Wall-E is 16.5 x 21.6 x 26.7 cm Size of U-Command Wall-E is 20.3 x 27.9 x 34.9 cm
You lose a good amount of space and I am guessing the workings inside may be different.
