Websocket Client icon Websocket Client — WebSocket client for ARC: open/send messages, store server responses in a variable, run a response script, and track connection status. Try it →
Netherlands
#17
Hey Rich,
I like the wireless cam. eye for wall-e. The one in the developers kit is different.
it looks not as the same as on the picture you know!:):):)
But thanks for your help!
#18
That's because it isn't the same. But it's better, much better! If you can fit it in I would highly recommend using the V4 camera over the wireless one from the V3 developers kits.
#19
You probably thought it was 5v because it has a USB charger, so if you power through the USB port there is either a regulator or the battery acts as one. Before trading it to another member, I powered mine with 5v from the EZ-B v3 with the battery removed and it worked fine.
Netherlands
#20
Okey Rich.
Than i will try both, so i can see whats better !
Can i also use the mini usb input of the wireless cam to power it from the ezb -4?
#21
Re: mini USB. Yes, but again, you will need a voltage regulator to bring the power down to 5v.
Netherlands
#22
Okay Alan,
Thanks a lott for helping me!
To all of you, thanks a lott that you helped me with this project!:D
Mvg, Jorrik
