Feetech RS485 Servo icon Feetech RS485 Servo — Control Feetech serial bus smart servos via EZB UART or PC COM port in ARC using virtual ports mapped to servo IDs. Try it →
#17
sure i guess. i think that will help future roboteers like me with this topic.
#18
I still learn something new every day, I didn't realise that you can power an LED from the signal wire.
So yes, DJ has a much simpler solution. Snip off a servo extension, wire the LED directly to the black and the white wires just like in DJ's pictures.
#21
Yep, they will do.
#22
k i was getting skeptical about thoughs wondering if they were right or not.
Thanks. when i start my project in the project showcase in march ill give you and Dj a shout out.
#23
On the I2C BlinkM, you seem a little confused on how to wire it up. It connects to the I2C port not to the Digital ports. So it has 4 wires from the I2C header on the EZB to the 4 connections on the BlinkM. Just marry up the connections on both... that's if you go down that route.
