MPU9150 Accelerometer, Gyro, Temperature, Compass icon MPU9150 Accelerometer, Gyro, Temperature, Compass — MPU9150 ARC control reads compass, gyro, accelerometer and temperature via I2C, initializes and sets EZ-Script variables on demand. Try it →
Wall-E Question Quick
here's the notepad info:
The Real Wall-e without Script Manager
Camera Power: D1 ModifiedServoMovementPanel: D13, D14 Left Arm: D8 (low 8, high 36) Right Arm: D9 (low 56, high 28) Left Eye: D15 Neck Horizontal: D6 (center 32, 50, 20) Head Vertical: D7 (center 35, high 44, low 24) Ping: (Trigger d2, response d3)
What is the left eye servo? theres head vertical and horizontal so it cant be them. ?
Hi,
I don't have ARC available right know, so i cannot test the example you're referring to. But if I remember well, Left Eye: D15 do not refer to a servo but to a Digital Trigger for the Camera, which is hidden in the left eye of wall-e.
yea i took a look at his scripts(which was confusing) and started assuming that.
Thanks though
When you open the project you should see a digital on/off control for D15 or a servo control for D15. I assume it's a digital on/off for the signal to the camera.
If there is an Init script I would expect there to be a Set(D15, on) command in there, if there is then it confirms it's a digital on/off for the camera.
