Train Vision Object By Script icon Train Vision Object By Script — Train camera vision objects via controlcommand(), attach camera, start learning, monitor progress, and return object name for scripts. Try it →
Wall-E Wheel Question
Howdy fellow bot heads!
I have removed the wheels assembly from each side of my Wall-E frame but can not figure out how to get the wheels separated to attach my servos. Hope I'm making myself clear here. I'm talking about the rear drive wheel. I can't get the inside hub off the outside hub. I have tried to pull and pull but I'm afraid I'm going to break it.
Any great words of wisdom from fellow Wall-E builders?
Herr Ball
I had the same issue.
There is a screw that is holding on the tire(s). On certain Wall-E models you had to pry off a rubber cap to access it.
On mine they were glued on hard plastic caps, so I ended up drilling a hole, center of the hub, using a 1/8" drill bit. Once you get those screws out it all falls apart.
Lol I scratched my head for a bit too when I first got my Wall-E.
I forget which tutorial here had the pics. I'll see if I can track it down.
@Lumpy
Thanks for the heads-up about the screws:) I too had the glued on hard caps. I would have never known they were caps either! Looked like just part of the wheel assembly. Again thanks,
Herr
