Auto Position (Gait) icon Auto Position (Gait) — Create servo frames and actions to animate gaits and gestures with automatic motion planning, software ramping, movement panel, import/export Try it →
Hey DJ, a little clarification please. When I saved the "Wall e Big" file as a document; then opened it I'm seeing what I presume is promgramming code. Is this correct? I then opened it in ARC and it would appear that all the programming is there and ready to "start". Could it actually be that easy????????? Once the physical robot is constructed, per your assembly guides, and the program is saved in ARC, you are ready to rock and roll??????? Does the EZ B board, or ARC, convert the simple programming we put in the "configure" console into programming code? T hanks, Lloyd
Gunny, still can't find it! That's what DJ suggested also... Under ARC it shows a screen print of the wall-e big file opened up but I don't see where to d/l the file! I might be looking right at it but getting cross-eyed looking at that page! Thanks!
Hey milanmark
Your talking about the ARC area on this webpage right? I was referring to the actual ARC program you use. Im believe recently DJ added examples to it, so once you open it, Select the File Tab and under it there should be a Examples option and in there is one for wall-E.
Im still waking up, so hopefully im not getting all confised:P
Got it! I was looking under the webpage.... Looked in the software program and found it! I had a version dated 11/7 on my desktop... not there, I had just d/l to my laptop today and that version dated 11/22 has the examples! Promptly updated my desktop! Now back to playing with the board! Thanks for the help!
Great to hear! Yeah i usually at random times just update the ARC just incase i missed one. DJ is always adding fancy new features:)
