He DJ Sures,
In one youtube movies you show that you dremeld the voice eprom and changed it a little to integrate it with the EZ-B how did you do that?
I want to do the same
Feetech RS485 Servo
— Control Feetech serial bus smart servos via EZB UART or PC COM port in ARC using virtual ports mapped to servo IDs.
He DJ Sures,
That was on the little wall-e i had built. It was from the Interactive Wall-E. I don't recall what wires I used. I can check the robot when I am back in Calgary. I'm currently 2,400 KM away for the next 3 weeks.
That's right I have the Wall-e I. I've watched your movie a lot of times and just can't see enough to try it.
Okej that's far far away
On a holiday ?
If so enjoy !!
bump, can this be added to a big wall-e (u command wall-e?)
Don't know, have to wait until Tuesday. Than i get my "U Command Wall-E"
The interactive wall-e it was easy to do, if you watch the demo movie of the making off wally by Djsures.
But if the U command layout is the same as the interactive it's just seeking for the right connection and solder away
Trying is the best way
