Tic Tac Toe icon Tic Tac Toe — Play Tic Tac Toe with your ARC robot: configurable turn, win and draw scripts, cheat commands and optional speech-recognition control. Try it →
#17
What is that plug with 6 pins on the middle left of the board beside the proccessor? theres power outputs there. And there's also that 2 pin plug above D14.
#18
Read my original reply in this thread
#19
sorry about that. I missed it. so the expansion port is the one with 6 pins? if so, what about the 2 pin port above d14?
#20
It's just a gnd and +5. Extended off the row of digital labelled pins.
#21
that would work? it would turn on with the ez-b, right?
#22
As DJ has mentioned, if you want them to come on with the EZ-B and have no control over them then use the +5 and Ground on the side expansion port.
The +5 and Ground of the digital track should also work if you really wanted to use them.
#23
side expansion port and 2 pin ports can both be used. ok. now I know what to do. thanks everyone!i!
#24
I could have sworn that I used the variable on the Analog ports. But, you guys have a better memory than me. You have to take what I say with a grain of sand.
