EZB Connections icon EZB Connections — Add and manage up to 255 EZ-B I/O controller connections in ARC, select COM/IP ports or device addresses to connect or remove devices. Try it →
Weak Thumper 4wd
Weak Thumper 4Wd
I'm trying to build a mid-size robot using the Thumper 4wd and two 2.5 Amp motor controllers and 12v/12Amp battery to run it but I don't have torque to turn it around (only to go forward/backwards). Actually I can easily stop the wheels with my hands. However if I will connect the motor directly to the battery I can't stop it from turning. So my guess is that the 2.5 amp is not enough or something is wrong. There is any quick fix for that on the 2.5 amp controller or should I get a new motor controller? Or. I'm pushing the unit to the limits Help..
#33
Hi Robotdude,
I have the Thumper 4WD and I am using the same setup as you with the 2 H-bridges from the EZ-Robot store. It works fine for me, but I don't have anything heavy loaded on mine. Just some sensors. I usually run the H-bridges at 50% of power to get a reasonable speed for indoor use. Did you make sure that your batteries both have a common ground?
Also, can you post a diagram of the other wires you are using for the digital connections from the EZ-B?
Finally, what "indoor wheels" did you buy? I am trying to find some for mine.
With the big outdoor wheels I found that turning on a carpet was very difficult. In order to execute a turn I had to use a custom Movement Panel and set the speed on one side equal to about 20% of the speed on the other. For example, to turn right, I set the right-side wheels to 10% power and the left-side wheels to 50% power. That seems to work best.
Thanks, Mike
#34
Hi Mike, My robot weight around 9kg and everything is connected to the same 12v battery so there is a common ground. I wired the digital ports similar to https://synthiam.com/Community/Questions/2745 So I combine the wires together to save ports on the EZB I used a very simple kid's bicycle training wheels with some small modification to make it fit into the motors. Are you sure that the 2.5 amp h bridge are enough for the Thumper 4wd? Why if I connect the battery directly I will get more torque? That shouldn't happen if the h bridge is strong enough no?
#35
I think the main difference between my Thumper and yours is the 9kg of load on yours. I can assure you that I only need 50% power with the h-bridges to go pretty fast around my house. But I have almost zero load. So I haven't tried it with a large load .
What wheels did you buy for inside use?
